Results 1 to 10 of 11
    Jr. Apprentice charlie268's Avatar
    May 2008
    Lykens, Pennsylvania
    Default Rochester Carburetor
    I have a rochester 4bl carb on my 77 pickup. Just had it rebuilt and was wondering about the mixture screw. I remember years ago I used to hear that you screwed the mixture screw all the way in ant then backed it out so many turns. Does anyone remember this?
    Best way is with a tach but the old tried and true way is to turn it in slowly till it misses <this is a lean miss> then back it out 1 turn.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    May 2008
    My carb is a 4MC and I can only find the idle screw on the driverside in the front. Where is the mixture screw located?
    Sr. Apprentice kaiah723's Avatar
    Bridgeport, CT
    i had to do this to my 84 monte ss. i played it by ear and it worked well
    2009 cobalt ss, imperial blu metallic, lsd, dejon powerhouse intake, Dejon bpv spring upgrade, Trifecta tune, clutchmasters aluminum flywheel, clutchmasters stage 1 clutch, 20% tints,
    2008 avalanche ltz, imperial blue metalic, k&n cold air intake, Gibson cat back duel exhaust
    Quote Originally Posted by charlie268 View Post
    They are on the front of the base plate probably under some covers. You have to remove the covers to gain access to the screws. I always start about 2.5 turns out and then do the method described above.
    Gary
    99 K 1500 Suburban
    00 S-10 Blazer
    1976 Trans Am
    1980 Honda CB900 Custom
    May 2008
    Thanks, found the screw and did what you said!!!
    May 2008
    I started this thread and thought I had solved the problem, but have one question. I located the screws on the base of the carb. One is on the drivers side base and the other is on the passenger side of the base. Does anyone know which is the idle and which is the mixture? I looked on line and found one source that told me they were both idle screws!
    Correct Charlie, they both are mixture screws.
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
    May 2008
    Should they both be set the same?
  1. Greetings from Rochester NY
    By Deadkennedys29 in forum Member Introductions
    Last Post: 06-18-2010, 01:48 PM
  2. Greetings from the north coast, Rochester NY
    By nitrozamboni in forum Member Introductions
    Last Post: 10-13-2009, 08:33 AM
  3. Carburetor adapter for a Edelbrock 1406(Performer)
    By David8790 in forum General Chevy & GM Tech Questions
    Last Post: 09-15-2009, 04:12 PM
  4. Carburetor question
    By santori1 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 06-23-2008, 03:39 PM
  5. Greetings from Rochester, WAshOut
    By Robert1951 in forum Member Introductions
    Last Post: 04-22-2008, 05:09 PM
