    Question transmission wires
    I need to know what wires go where i went from a 4L60E with a round plug to a 700R4 with a square plug i need to know were they go
    I'm not sure what wires go where, but I do know that alot of them will probably not be used. The only thing electrical going in/out of the transmission case is the reverse light circuit and the torque converter lockup control.
    Christopher
    You will need only 2 wires to make the 700 work. B+ voltage from the brake switch and the ground signal from the computer. Your problem will be when the computer sees it has no EPC control it will disable lock up and try to put your transmission in failsafe, which of course it can not do. So you will have no lockup and if you drive it this way you will fry the converter in short order.
    To make this 700 work you will need to install a lockup kit.
    Summit sells Painless Lockup Kits as well as TCI. Several other companies make these kits. The bottom line is your 4L60E computer will not make your truck lock up without some help from an aftermarket kit. HTH
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
  1. Wires, wires, wires....and more wires.
    By J.mesenbrink in forum Chevy C/K Truck Forum
    Last: 10-19-2009, 07:56 PM
  2. which wires do i tap amp into?
    By burbalex6.0 in forum Audio, Video & Gadget Tech
    Last: 06-11-2009, 11:05 PM
    Last: 06-08-2007, 11:53 AM
  4. Replies: 0
    Last: 06-08-2007, 09:20 AM
  5. Aftermarket Sparkplugs wires vs Chevy Sparkplug wires
    By chevy00 in forum Chevy Silverado Forum (GMC Sierra)
    Last: 10-19-2005, 10:17 PM
