Results 1 to 7 of 7
    Newbie spencer is a glorious beacon of light
    Apr 2009
    Default 2006 silverado limp mode with HID's
    I've got an issue with my bosses truck. It is a 2006 silverado with a 5.3 "B" motor. It goes into limp mode at first start up. It has all the stock headlights replaced with HID's. The low beams and fog lights both are hooked up to a relay kit. If you turn the headlights on and off you can get the truck to go back into limp mode after clearing the codes. The PCM is under the hood and pretty close to where the ballasts are mounted. I was wondering if anybody has encountered this, and how to isolate the ballasts. My theory is that their is some sort of radio interference from the ballasts. i get a passel of codes when it is in limp mode, all related to the app or throttle body. i've replaced the throttle body twice, reprogrammed the pcm and checked all of the wiring. The only additional info I have is that I could not program the PCM in the vehicle, I had to do it in another vehicle. Im looking for a way to isolate the ballasts because im pretty sure he doesnt want to pull them out. thanks
    spencer
    Legend bry2500 is a glorious beacon of light
    Oct 2008
    Gloucester, MA
    Sounds like a wiring messup. It will be a pain but to get it done right you may have to pull em out and start from scratch on the install. Even go back to stock headlights and see if the problem goes away. if it doesn't them I would say it's a new PCM for the truck. hope it all works out.
    Welcome to the site!!!!!!
    BRYAN
    "IF YOU DON'T TREAT IT LIKE A TRUCK IT'S JUST A REALLY BIG CAR"
    02' Avalanche 2500 Onyx Black
    8.1L Vortec
    43,000 miles
    Legend Z71_guy is a splendid one to behold
    Feb 2009
    Minnesota
    welcome to the site
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    Please post the codes. The actual code(s) tell you exactly where to start your diagnosis. Also exactly when does the code set?
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
  5. #5
    Moderator
    dwill3015 has a reputation beyond repute
    Jan 2007
    Yacolt, Washington
    Welcome to the site and as Jim mentioned, post those codes!
    Darcy
    Washington State
  6. #6
    Legend bob13 is a glorious beacon of light
    Feb 2009
    NE Pensylvania
    Welcome, the frequency idea does not sound right, post the codes and I am sure the guys on this site can help you!
    The diference between stupidity and genius is that genius has limits.
    2007 NBS Silverado
    LT2 Z71
    2.5" Levelling Kit
    Hood Stripes
    Chrome Grill
    GM Bed Liner & Tonno
    Dick Cepek Rims 18X9
    Hankook RF10 Tires 275/65/18
    De-Badged Tailgate
    More Mods Coming
  7. #7
    Apr 2009
    Quote Originally Posted by bry2500 View Post
    They are plug and play, even with the relay kit, there really is no way to mess up the wiring. i read somewhere else last night that a bad ballast can cause it, so i swapped out the ballasts for some spare ones we had laying around. i couldnt get it to duplicate after that. as for as when it happens, it used to happen going down the highway, but now it only does it at startup.
Similar Threads
  1. 2004 Chevy Silverado Tow/Haul Mode
    By Tripleblack in forum Powertrain
    Last Post: 01-29-2012, 12:43 PM
  2. 4l60e limp mode
    By crossleysierra in forum General Chevy Tech Q&A
    Last Post: 02-22-2010, 04:15 PM
  3. 07-09 Silverado end caps w/fogs+6000k HID's
    By JAKD-UP in forum For Sale & Wanted to Buy
    Last Post: 03-17-2009, 09:33 AM
  4. Limp mode activated with low beams
    By GlitchMobile in forum General Chevy Tech Q&A
    Last Post: 12-12-2008, 09:23 PM
  5. mode door actuator 99 silverado
    By mgod12878 in forum General Chevy Tech Q&A
    Last Post: 11-05-2008, 09:11 AM
