Thread: surging issue
    Default surging issue
    Hello all,
    What's the best way to check for vacum leaks on a vortec?? My truck is a 1997 5.7.
    Thanks,
    John
    welcome to the site, you can always use the carb spray trick
    have the truck running and spray carb spray where ever there are vacuum lines and dont forget around the intake. just listen for the engine to stumble or surge
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
    Does your truck rev a few hundred RPM's when sitting at a stoplight with your foot on the brake? I know my 99 always does, I never found a fix for it....
    Dan
    1999 GMC Sierra 2500 350 vortec
    1967 Jeep M725 ambulance 230 tornado
    1990 Cherokee Limited- 3 inch lift on 33's
    ...and every one of em has issues
    If you have any questions or problems don't hesitate to send me or any other GMTC moderators a PM
    Quote Originally Posted by 95CTburb19 View Post
    No, it surges between 40 and 50mph. It doesn't do it at any other time or speed. I thought it might be the TC hunting (locking and unlocking), but I tried driving it in third gear and it still surges.
    It's not a severe surge just aggrivating! LOL
    Jr. Mechanic bd1326's Avatar
    Feb 2009
    Chardon, Ohio
    95CTburb19,
    sounds like the problem my 99 silverado had. when i started it it would idle higher than normal, at a stop it would either idle real low and stall or idle real high. it ended up being my throttle position sensor.
    bd1326
    2005 Chevy Silverado 6.0 Vortec 4X4
    K&N Air Filter: Stock Replacement
    E3 Spark Plugs
    Magnaflow Single Exit Exhaust
    Rough Country Leveling Kit
    Skyjacker Add-a-Leaf
    Much More To Come
    "Understeer is hitting the wall with the front of your car. Oversteer is hitting it with the rear."
    - NASCAR driver "Fireball" Roberts.
    Thanks I'll check it out! Mine will never stall though and seems to idle normally. I think the fact that it has 202k on it might play into it somehow.
    Dan
  1. surging 1994 Chevy Suburban
    By mudpuppy in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-12-2012, 09:40 PM
  2. rpm s surging
    By noahraysanders in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-27-2009, 10:12 AM
  3. air conditioning surging?
    By Clean-Dezert.org in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 09-16-2009, 04:27 PM
  4. Occassional surging
    By BlackHawk99 in forum GM Powertrain
    Last Post: 07-06-2009, 06:48 AM
