Results 1 to 9 of 9
    Default Trailblazer Vacuum llines
    I'm customizing my trailblazer. One thing i'm doing is putting in aftermartket guages one of which is vacuum guage but i have no idea where any of my vacuum lines are. Can anyone help me?
    Legend bry2500's Avatar
    Oct 2008
    Gloucester, MA
    Welcome to the site!!!!
    On the fan shroud or front frame near the hood latch should be a label with the vacuum line diagram. I have only one accessible vacuum line on my 8.1L and it is 1/8in diameter. I hope you don't have the same problem.
    BRYAN
    "IF YOU DON'T TREAT IT LIKE A TRUCK IT'S JUST A REALLY BIG CAR"
    02' Avalanche 2500 Onyx Black
    8.1L Vortec
    43,000 miles
    welcome to the site
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
    Welcome to the site! You could use a Chilton Manual or another repair book to give you that information. Maybe even online.
    The diference between stupidity and genius is that genius has limits.
    2007 NBS Silverado
    LT2 Z71
    2.5" Levelling Kit
    Hood Stripes
    Chrome Grill
    GM Bed Liner & Tonno
    Dick Cepek Rims 18X9
    Hankook RF10 Tires 275/65/18
    De-Badged Tailgate
    More Mods Coming
    Moderator
    dwill3015's Avatar
    Jan 2007
    Yacolt, Washington
    Darcy
    Washington State
    Moved to general tech
    You might post your year/engine, in case it makes a difference in vacuum supply.
    You can install a "T" fitting in an existing vacuum line easily enough. The harder part will be determining which lines are 'constant' vs 'ported' vacuum. Constant vacuum sources always see a vacuum. 'Ported' vacuum is only present at certain throttle settings (typically no vacuum at idle, but normal vacuum above idle throttle opening).
    Typically, any vacuum line that terminates directly into the intake manifold is a constant vacuum source. Examples would be the fat hoses that lead to the power-brake booster, PCV valve, or a choke-pull-off on older carbureted trucks.
    Any lines that terminate in the throttle-body can be either ported or constant. Absent the factory manuals, the only way to know for sure is to connect a temporary vacuum gauge and see if it registers full vacuum at idle - generally that indicates a constant-vacuum source.
    Kirk
    Norwalk, CT
    Sr. Apprentice leadpan101's Avatar
    Nov 2008
    Millersville, MD
    i am actually a friend of the guy who posted this, and we figured it out thanks for the help?
    Leadpan101 :great:
    2003 Chevrolet Silverado Z71
    1996 Honda Accord
    Last: 07-13-2010, 04:40 PM
  2. TBI vacuum line kit
    By bigdaddy77084 in forum GM Powertrain
    Last: 03-10-2010, 08:28 AM
  3. Vacuum Line???
    By jnbascom in forum GM Powertrain
    Last: 12-14-2009, 07:58 PM
  4. Vacuum diagram
    By timmottesh in forum General Chevy & GM Tech Questions
    Last: 09-18-2008, 01:24 PM
  5. Possible vacuum leak?
    By codygs1 in forum Chevy Trailblazer Forum (GMC Envoy)
    Last: 06-27-2008, 02:54 PM
