Results 1 to 3 of 3
    Newbie Adirondacker is a glorious beacon of light
    Apr 2009
    Default 2007 Suburban alternatorelectrical problem?
    My 2007 Chevy Suburban 1500 has been showing a possible electrical problem on the gauge that shows if the battery is charging. It will randomly fluctuate from above 14 volts down to approx 10 volts. I was driving for 3 hours yesterday. I noticed it drop down in voltage. I stopped and restarted the vehicle and it went up to 14+ volts and then 5 minutes later back down to 10 volts. Stayed there for about 10 minutes and jumped back up. Did it a few more times. Then stayed constantly above 14 for the remaining 2 hours of the trip. Then is seemed fine but then started happening again.
    Is there a way to tell if this is my alternator? How?
    Could it be some other problem? Sensor or something?
    Any thoughts on how to troubleshoot this would be appreciated.
    Thanks.
    Jr. Engineer Jacqson is a name known to all
    Jan 2009
    North Vancouver, BC
    Quote Originally Posted by Adirondacker View Post
    Thanks.
    Take your truck to a reputable Automotive electrical shop and have the alternator tested. My guess is it's the gauge. The ECM monitors the charging system and if you get voltage fluctuation, it will throw you a code on the DIC.
    2011 Chevy Silverado 3500HD, Taupe Gray Metallic, Line-x over the Rail
    "Suburban" There is no Substitute.
    For Sale- My Loaded up 02 2500 Suburban
    Legend Springthing has a reputation beyond repute
    Aug 2008
    East of Branson, Missouri
    1 Thread(s)
    I agree that it's the gauge. If the problem happens enough it's an easy check... get a voltmeter and test the voltage at the battery. If the voltage on the gauge fluctuates but the voltmeter stays the same then it's your gauge.
    With that year truck, though, you should be able to just take it in under warranty and have them test/fix it.
    Steven
    "The Sarge"
    1999 Chevy Suburban LT- K2500
    7.4 454 Vortec, 4WD
    305/70/16 on Eagle Alloy
Similar Threads
  1. 2007 avalanche 2wd trans problem
    By phazelwood in forum Powertrain
    Last Post: 05-10-2010, 10:39 PM
  2. 99 suburban problem
    By rwslippey in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-25-2010, 10:23 PM
  3. Entrertaiment System Problem - Trailblazer 2007
    By Mixtico in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 09-27-2009, 12:52 AM
  4. 2007 Suburban lift problem
    By trojans1981 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-16-2009, 11:00 PM
  5. 95 suburban 4X4 problem?
    By 95CTburb19 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 10-12-2007, 02:36 PM
