Results 1 to 7 of 7
Thread: Power Wire?
    Jr. Apprentice Chevysilverado05 is a glorious beacon of light
    Apr 2009
    Default Power Wire?
    Hey guys just a quick question, I am currently installing some subwoofers in my truck I can't find anywhere to run the power wire my truck is a 05 silverado regular cab by the way that might help, I don't want to drill a hole in the firewall and I want this to be a clean install any ideas???
    Legend ct9a is a glorious beacon of light
    Jun 2008
    Colorado
    I've always run them from the battery. You can usually use existing holes in the firewall where the wire harness passes through. Worse case scenario, you drill a hole and put a grommet in there.
    I guess you could also find a 12v ignition power source at the fuse box, but I'd be a little concerned of over taxing the circuit.
    Scott
    ΜΟΛΩΝ ΛΑΒΕ
    '94 Chevy Suburban K1500
    3" exhaust w/ aero turbine non-baffled muffler
    CFM Technologies TB spacer
    CB w/ 44" whip antenna
    Apr 2009
    thanks for the tip, I thought about doing that but there is absolutley not one space for this wire it's 4 gauge so it's reasonably small. I did find an open space in the fender but I'd have to run the wire through the door and do not want to do that. but it may be my only option
    Legend Springthing has a reputation beyond repute
    Aug 2008
    East of Branson, Missouri
    1 Thread(s)
    I know you said you don't want to drill a hole through the fire wall but to my knowledge there's no other way to get a wire inside, unless you want to drill a hole through the bottom of the body somewhere.
    If you don't want to take on the task of drilling a hole then may I suggest you take $20 and head to your local garage/mechanic. I'm sure they'd have the tool(s) and expertise to drill a hole for you and put in a grommet to ready it for you to stick a wire through.
    Good luck with your project,
    Steven
    "The Sarge"
    1999 Chevy Suburban LT- K2500
    7.4 454 Vortec, 4WD
    305/70/16 on Eagle Alloy
  5. #5
    Former Member TRPLXL2 has much to be proud of
    Jan 2009
    Norwalk, Ohio
    2 Post(s)
    1 Thread(s)
    Oh yeah I know what your talking about with the front fender, I was going to do that with my off-road lights but the harness was too thick to run through the door. That is a spot that very few people actually know about too, that's to bad you can't go through there it's a very clean way to run wire through the cab into the engine compartment. I would tell you how I routed my wires without drilling holes, but it's no good for your speaker wire. Good luck................AMY
    DRAIN PLUGS UNDER DIVER SIDE FLOOR BOARD
  6. #6
    Legend bry2500 is a glorious beacon of light
    Oct 2008
    Gloucester, MA
    Drill the hole, Get a grommet. It's the proper way to do it. Make sure you find a location that's easily accessible and is in a location the the wire can be hidden directly after coming out of the firewall. I did this in my Nissan frontier when I installed the amp. I used a little more cable to route it neatly and right, but it was worth the effort. You couldn't see a wire in the truck at all.
    BRYAN
    "IF YOU DON'T TREAT IT LIKE A TRUCK IT'S JUST A REALLY BIG CAR"
    02' Avalanche 2500 Onyx Black
    8.1L Vortec
    43,000 miles
  7. #7
    Apr 2009
    Thanks guys for all the help I guess I'm either gonna drill the hole or get someone else to do it for me It's gonna be a cleaner install, and easier to do
Similar Threads
  1. Switched Power Wire Needed!
    By Milwaukean in forum Audio / Video Electrical
    Last Post: 11-09-2010, 01:41 AM
  2. Fuel Pump Power Wire/Connection - Location?
    By alchemist1 in forum Powertrain
    Last Post: 10-07-2009, 10:20 AM
  3. installing power wire for amp???
    By kylegillean in forum Audio / Video Electrical
    Last Post: 07-20-2009, 04:02 PM
  4. Amp Power Wire Routing
    By Tdaz250 in forum Audio / Video Electrical
    Last Post: 01-21-2009, 02:55 AM
  5. Amp Power Wire Question
    By JOnNyAZ in forum Audio / Video Electrical
    Last Post: 07-18-2008, 06:05 PM
