After 185K my whip antenna finally snapped off in the wash. I found an original Antenna mast, but don't know if I need a special wrench to remove the remaining stub and install the new mast.
Any advice would be greatly appreciated.
Thanks
If its like mine a small end wrench or adjustable should work fine if its just the mast part and not the base.
Your welcome! Happy to help!
One thing about car washes I noticed with mine is the coating on the mast was getting beat off and I was afraid the wire that wrapped around would come off.
To fix this I got a roll of heat shrink tubing 1/4 inch from harbor freight and ran it all the way down the mast with a litte extra cause of the shrink factor, used a heat gun to warm it up and it shrunk down snug and it looks good and should be pretty durable time will tell tthough.
My trucks!
1996 GMC Suburban SLT
1997 GMC Yukon SLT
Bookmarks
