Thread: EVAP selenoid
    Default EVAP selenoid
    i have a 1999 silverado ext. cab with a 4.8 litre engine.
    i got a code from my engine that i was having problems with it and i was told that if i take it off and clean it out it will take care of my problem... is this true??
    Thanks,
    99 silverado driver
    (Dan)
    My mom had her check engine light come on in her 2001 Chevy Blazer, and when I scanned it came up with the evap canister. We pulled it down and found a charcoal liner or filter in it, we replaced the charcoal and replaced it. I reset the MIL and it never came back on, I don't know if that helps or not.
    Cleaning the valve might resolve the code, if a dirty valve is the cause of the code.
    Some EVAP codes can be caused by not putting the gas cap on tight.
    If you post the actual code (my code list gives a dozen or more different EVAP codes), someone with the right manual may post specific diagnostic information.
  1. Gas going into evap box
    By solo3500 in forum Performance & Fuel
    Last Post: 11-10-2009, 01:52 PM
  2. Evap Emissions?
    By BigJosh in forum General Chevy & GM Tech Questions
    Last Post: 09-27-2009, 02:53 PM
  3. Help with EVAP Cleaning
    By ejj in forum General Chevy & GM Tech Questions
    Last Post: 09-18-2009, 04:29 PM
  4. EVAP System?????
    By cchas14 in forum Performance & Fuel
    Last Post: 07-08-2008, 01:05 PM
  5. Evap Canister Issue
    By rajahnme in forum GM Powertrain
    Last Post: 12-20-2007, 12:14 PM
