Results 1 to 9 of 9
Thread: MPG Boost
    Jr. Engineer Tdaz250 is a glorious beacon of light
    Dec 2008
    Oregon
    1 Post(s)
    Default MPG Boost
    Hey everyone I'm looking for some input on what to do for getting better MPG. I have gotten an intake replaced the muffler and switched over to synthetic oil and now I get around 12 to 13 mpg in the city. What are the next things I should get ? I'm looking into getting a programmer but what else is there ? What does getting a new maf do ? I'm just looking for any input on what to do. Thanks!
    2000 Chevy Silverado 1500 5.3L Z71 - 4x4
    Legend
    ippielb is a name known to all
    Feb 2009
    Canada
    Well, just with my experience so far, getting a throttle body spacer will increase your low end torque, and give you better mpg with stopping and going. But beware with the spacer, airaid poweraid spacer will not it with the K&N 57 series. As you have the same body style as my truck. Just try and clean the engine out with some seafoam might help as well.
    2002 Chevrolet Silverado 1500 z71
    6.5" BDS Suspension Lift Key'd to 9"
    5.5" Lift Springs with 4" Blocks
    35" Toyo Open Country Mud Terrain on 18" Ion Alloy 179's
    AirAid Cold Air Intake with K&N Dry Filter & AirAid PowerAid Throttle Body Spacer
    Pacesetter Long Tube Headers with Catalytic Converters Removed and True Dual Exhaust FlowPro Mufflers 4" Stainless Tips
    Bosch +4 Iridium Spark Plugs MSD Ignition Plug Wires
    Innovate LC-1 Wideband o2 Sensor x2
    BDS Dual Steering Stabilizers
    Electric Fan
    4.56 Gears
    EFI Live
    Jr. Mechanic ukrkoz is a glorious beacon of light
    May 2007
    1. there are no power mods that will improve mpg. period, end of sentence.
    2. HALO spark plugs.
    3. hypermiling driving style.
    http://en.wikipedia.org/wiki/Hypermiling
    http://en.wikipedia.org/wiki/Fuel_ec...zing_behaviors
    4. keep you truck bed open and tailgate up.
    4. low resistance tires
    5. properly inflated tires.
    6. pick your poison here:
    http://peswiki.com/energy/Directory:Fuel_Efficiency
    I really like how Scangauge influences my driving. If you start watching that mpg changing, foot does the rest by itself. I think, there are other, cheaper habit modifying devices out on the market, but all of them show you your instantaneous mpg, so you become aware of that gas pedal more.
    oh, btw - cheap gas=poor mpg. go back to Chevron, truck is tuned to it as standard gas.
    DON'T FIX IT IF IT AIN'T BROK. IF IT'S BROK - FIX RIGHT AWAY.
    WONNA THINGS DONE RIGHT, DO THEM YOURSELF
    2000 SILVERADO, CENTURION EDITION, 4WD, Z71, 5.3 VORTEC
    NO DUMM MODS
    Former Member TRPLXL2 has much to be proud of
    Jan 2009
    Norwalk, Ohio
    2 Post(s)
    1 Thread(s)
    A Granatelli MAF will get you 7-8 more horsepower, and that is about it. I had one on my old 2004 2500HD with the 6.0 and 4.10 gears, they advertise 1-2 mpg better than stock but there is no proof to that and my driving style is too harsh to gain anything anyways.
  5. #5
    Dec 2008
    Oregon
    1 Post(s)
    How does changing the plugs change MPG? Also does new fans do anything(i've seen electric fans or something like that) also what is with people saying they have a "160 Thermostat" and stuff like that? can anybody explain? Thanks!
  6. #6
    Sr. Apprentice mburn039 is a glorious beacon of light
    Feb 2009
    Kutztown, PA
    Well first of all there are definitely power adders that can increase mpg. period. end of sentence.
    Turbo, supercharger, exhaust, dyno-tune, etc.
    Mike
  7. #7
    Sr. Mechanic bac-n-afect is a glorious beacon of light
    Jan 2009
    Davenport, Iowa (the quad cities)
    A new set of spark plugs will ignite the fuel/air mix more efficiently. Translated---> You will have a more complete and instantaneous ignition closer to the top of your power stroke. Basicly getting more power from the gas you would be using anyway.
    Fans---> I can't speak with as much authority on this subject but I believe I have the concept down... Older engines were set up so that the pistons would churn the crank the crank would spin both the flywheel/transmission and the water pump, harmonic balancer, and the fan.
    Newer engines comonly use electric fans thus creating less drag on the crank.The electric fans are controlled by thermostat temperatures and actually only spin under power when they are needed for cooling. Hopefully someone else will come along and verify or debunk my thinking.
    Honestly the best way to save on gas is to try not to drive Or to carpool. Sorry but short of driving a hybrid, there just isn't one change you can make that will make your MPG skyrocket.
    Marc
    2008 Chevrolet Silverado
    Black on Black leather, XM,
    20" GA 4.6
    Bak Flip G2
    5.3L FLEX
    Custom machined bow-tie
    (my ME ; )
    Billet grille inserts
    Paint Matched
    door handles & mirror covers
    Partially de-badged
  8. #8
    Dec 2008
    Oregon
    1 Post(s)
    Quote Originally Posted by bac-n-afect View Post
    Yeah i hear what you mean, i'm trying to carpool more. Im just looking for stuff thats going to push me into the 15mpg range around town. I drive around town pretty much like 80% of the time, driving on the freeway every so often and i always get 12-14 mpg, and it would be nice to have a guarrenteed 15 mpg at least. I know everyone is going to say get a chip/programmer, so i'll ask questions about that in another post.
  9. #9
    Sr. Apprentice jrose7 is a glorious beacon of light
    May 2008
    Wilson, N.C.
    What are Halo spark plugs? I'm getting ready to replace my plugs, and have wondered what to get.
    jack
    2004 Ext. cab Silverado
    5.3L; Fujita CAI; Airaid throttle body spacer;
    Hypertech programmer;
    305x40x9.5 on Panther 22's
Similar Threads
  1. Boost??
    By rockfoot in forum Diesel & DuraMax
    Last Post: 04-07-2010, 12:14 PM
  2. boost
    By rockfoot in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-23-2010, 07:32 AM
  3. just how much boost is suggested???
    By Jimbo74 in forum Powertrain
    Last Post: 05-09-2009, 10:05 AM
  4. Question about boost.
    By spenc938 in forum Powertrain
    Last Post: 10-30-2008, 11:55 AM
  5. More boost? [Expired Topic]
    By Davandy in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 08-15-2005, 04:59 PM
