Results 1 to 8 of 8
    Jr. Apprentice 97BurbanSLT is a glorious beacon of light
    Apr 2009
    Default Intake Manifold Gasket Woes
    Hey guys my 454 has 140,xxx miles on it and needs and Intake manifold gasket. I was really concerned scince I just bought it however it looks like according to quite a few posts on the forum that its a pretty common issue with these vortecs. I'm going to change my valve cover gaskets while im tearin things apart. I was wondering is there anything that I can or should do while i'm replacing the Intake manifold gaskets to make the repair more effective or a better quality repair or last longer? It just makes me leary such a big engine having plastic or what seems to be plastic intake gaskets. Anyone ever tried to make their own??? Howd it go if youi did??? Thanks guys
    1997 GMC Suburban K2500 SLT AUTO 4x4 7.4litre 454ci. "ALL STOCK" (NO MODS)
    Legend MrShorty has much to be proud of
    Jan 2006
    Utah
    Reportedly, GM has redesigned the gasket, so, if you get it from them, be sure you get the new design.
    However, it seems most people prefer Fel-Pros gasket kit for this application.
    '98 K1500 Suburban LS 5.7 L 4L60E NV246 ARB
    '92 Ford Explorer XLT 4x4 4.0 L A4LD BW13-54 Trac-loc rear
    "My toys were the greasy cogs and springs and pistons that lay around all over the place, and these, I can promise you, were far more fun to play with than most of the plastic rubbish children are given nowadays." Danny in Roald Dahl's Danny The Champion of the World
    Apr 2009
    fel-pro is what i have I work part-time for advance autoparts when im not at my full time job or school and used my discount to my advantage. I try to steer away from their parts most of the time, i've had way too many bad experiences with their rebuilds and even longevity issues with some new one. I reckon the little korean kid left his bubble gum in the brushes during reman of that last starter i tried. Any who thanks for the advice and heads up about the updated gm version. any other advice on any additional measures to take to go above and beyond on this repair would be awesome thanks guys lovin the forum already.
    Master Mechanic Dr_Zero is a name known to all
    Mar 2006
    Sunny Florida
    I have the 350 vortec in both trucks and just had both done and went with the Fel pro they have a set for the 350 that comes with the improved gaskets and also all the other gaskets you might need including the distributor and comes with sealant.
    GM also re did the bolts since people were over torquing them and causing leaks the new ones are a tad longer and bottom out in the head so you cant overtighten and bust the gasket.
    I got the new bolts from Pace for about $2 aqnd some change each.
    http://www.paceparts.com/
    My trucks!
    1996 GMC Suburban SLT
    1997 GMC Yukon SLT
  5. #5
    Apr 2009
    Now should I really have a problem with damaging the gasket tho? I am planning to reassemble in a routine fashion torquing the bolts in an alternating pattern in equal incraments leading up to the 30ft-lb mark which is where all of them need to be according to the spec manual i looked up the torque spec in. If i am wrong please correct me. This whole plastic and aluminum combination is somewhat new to me guys thanks.
  6. #6
    Mar 2006
    Sunny Florida
    Check your gasket set and see if there are some new specs in there mine had a slip with some minor updates.
    If you do it to spec and in the right pattern you will probably be fine.
    My trucks!
    1997 GMC Yukon SLT
  7. #7
    Apr 2009
    I didnt see any in there but ill just use the standar pattern of crossing from the center to straight across on the ends.. Thanks for your advice i appreciate it.
  8. #8
    Apr 2009
    I know you have to remove the distributor on 5.7s, is that neccassary on the 7.4?? it looks like the manifold with clear i could be wrong tho just wondering. thanks guys
Similar Threads
  1. What intake manifold gasket to get? !
    By Dr_Zero in forum Powertrain
    Last Post: 05-29-2010, 03:56 PM
  2. intake manifold
    By mikemax in forum Powertrain
    Last Post: 03-19-2010, 01:30 PM
  3. I need a intake manifold
    By Blazedhertrails in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 07-20-2009, 09:23 AM
  4. Intake Manifold
    By Boltazar in forum Northeast (New England & Mid-Atlantic)
    Last Post: 11-02-2008, 11:48 PM
  5. finished: intake manifold gasket [Expired Topic]
    By MrShorty in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 11-04-2006, 01:37 PM
