Results 1 to 7 of 7
    Newbie wildmed21 is a glorious beacon of light
    Oct 2008
    Default 2003 2500Hd Vibration
    Hey I have a 2003 Gmc Sierra 2500 hd extended cab long bed truck that has a vibration that becomes worse between 40 and 50 mph. feels as though tires are out of round as it starts bouncing at 40 mph then smooths back out at 51mph feels as it is in rear. Have replaced tire and wheels twice with no change.any suggestions Thanks
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    If you swap the rear tires to the front and the vibration stays in the rear then its not he tires or wheels. The next place to look is your drive shaft. Best way to check it is to jack up the rear end and set the axles on jack stands with the wheels off the ground. Now run the truck in drive and look at the drive shaft. Usually you can see if its bent. A bad U joint will also cause a vibration like this.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    Oct 2008
    Thanks for the info. I have switched the back tires to the front and have also replaced the back tires,checked the u joints which appear to be tight, this problem didn't began until i installed new tires.
    Feb 2009
    Reno, Nevada
    Make sure you check the drive shaft run out. Coincidences do happen.
    Jim
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1970 Camaro
    2007 FJ Cruiser
  5. #5
    Oct 2008
    I have replaced both u-joints and still it feels as though the rear tires are bouncing between 40 and 50 mph.drivesaft does not appear to be bent or out of balance
  6. #6
    Newbie jlinc is a glorious beacon of light
    Apr 2011
    Default need help also
    What happened to the vibration. Mine also started after new tires were put on and is also at the same speed. Did you get it fixed? If so how. Hope you or someone can point in right direction. Thanks
  7. #7
    Oct 2008
    Had to change to different brand of tires, no problems now
Similar Threads
  1. 2003 Silverado 2500HD Crewcab
    By mattpresley in forum Chevy Trucks For Sale eBay
    Last Post: 01-30-2010, 01:09 AM
  2. 2003 2500HD Duramax 4wd problem
    By sarguy in forum Powertrain
    Last Post: 01-04-2010, 09:52 AM
  3. 2003 silverado 2500hd
    By coombia21 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 06-29-2009, 10:59 PM
  4. Duramax Driveshaft, 2500HD 2003
    By thpnalb in forum Powertrain
    Last Post: 03-21-2009, 02:31 PM
  5. 2003 2500HD intermittent no crank
    By eyeflyfish in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 12-27-2008, 08:25 AM
