Results 1 to 5 of 5
    Jr. Apprentice gunsap is a glorious beacon of light
    Apr 2009
    USA
    Default 1999 Burban issue after header install?
    Hey there all, I'm new here to the site and I'M experiencing a problem with my 1999 Burban k1500 5.7L. Last weekend I installed a set of headers all went well with the install with the exception of the air tube off of the header did not want to cooperate once I finally got it back on and started her up I noticed a vibrating almost grinding sound from under the hood almost sounds as if its up by the alternator I thought it was a bad baring on the belt tensioner or the idler pulling so I replaced both not it the sound seams to quit down at about 40 mph but does not go away also I notice a vibration from under the floor I have double checked every nut, bolt and the area I worked in. Any thoughts or help would be great Thanks
    Note: I am still running stock pipe, cats, and muffler I plan to replace once I pinpoint the noise
    Legend unplugged has a reputation beyond repute
    Sep 2006
    High Deserts of SoCal
    Last month I had a similar sound that started out intermittent, and it seemed to go away at higher revs. Then over two weeks it started getting louder and the noise started to get worse at higher revs. I poked around under the hood and since I had replaced the alternator recently I looked at elsewhere. There was a small amount of play in the fan so I wasn't sure if it might be water pump or the fan clutch. Took the fan clutch out and it was toast. A quick trip to the parts store and a new FC cured my woes.
    Not sure if that's whats ailing your burb, but its worth a look.
    There is no way to happiness....happiness is the way.
    http://kx6ijq.blu.livefilestore.com/y1pcOFVNH4ix1hjyGUVyXK5LRfef7qSeWzlZDorpQhIEfkZ2ZA  _vXMYypuKMJFw671uF2ZPhjez_j-atRmcjM2zQKpQi1JSsB75/burb1.JPG
    High Desert SoCal
    93 K1500 burb (personal) 350 AT 3" Lift 250K+
    02 Honda Civic LX
    Looking for a 1990's Miata for an engine swap
    Apr 2009
    USA
    Quote Originally Posted by unplugged View Post
    Great advise I will take a look at it tomorrow thanks for your input!
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    Did you figure out the dliemma? Other then that how was the header install? Did you go shorty or long tube? What kind and did you get any gains with them?
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
  5. #5
    Apr 2009
    USA
    Quote Originally Posted by vncj96 View Post
    I went with the shorty's from Summit Racing they went on supper simple as for any gains I have not drove it much since I put them on do to trying to figure out the sound I do believe its the fan clutch it appears to not be functioning correctly.
Similar Threads
  1. 97 burban power door lock issue
    By nyaristo in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-01-2010, 08:54 AM
  2. 1999 suruban install help
    By 99Burbon4544x4 in forum Audio / Video Electrical
    Last Post: 11-05-2009, 02:24 PM
  3. Issue with 1999 Burban after header install
    By gunsap in forum General Chevy Tech Q&A
    Last Post: 04-24-2009, 11:29 PM
  4. Replies: 1
    Last Post: 04-19-2009, 10:29 PM
  5. '03 'burban AC issue
    By bulump in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 10-17-2008, 06:19 PM
