Hey there all, I'm new here to the site and I'M experiencing a problem with my 1999 Burban k1500 5.7L. Last weekend I installed a set of headers all went well with the install with the exception of the air tube off of the header did not want to cooperate once I finally got it back on and started her up I noticed a vibrating almost grinding sound from under the hood it almost sounds as if its up by the alternator I thought it was a bad baring on the belt tensioner or the idler pulling so I replaced both, not it… the sound seams to quite down at about 40 mph but does not go away. Also I notice a vibration from under the floor I have double checked every nut, bolt and the area I worked in. Any thoughts or help would be great Thanks
Note: I am still running stock pipes, cats, and muffler I plan to replace once I pinpoint the noise
what kind of gaskets did you use?
1993 K1500 Suburban 350TBI, 378,486KMS on frame, 49,000KMS on Drivetrain. Lots of mods, built for haulin trailers and haulin @$$
2000 K2500 Yukon XL 6.0L Vortec 252000KMS custom CAI, and exhaust...but not done yet.
"If you are dumb enough to do something you don't know how to do, and can't do it safely then WHEN you get hurt its your own fault...BONEHEAD"
first off your gaskets that came with the headers are crap. I had a similar problem when I installed them and they blew out in the first 100 kms I put on. I bought some aluminum gaskets that are awesome. never have to be retorqued.
check em out if you can find them in your area
Bookmarks
