Hey guys;
New guy here. I have a question for yall. I have a 2004 GMC Sierra 5.3L with 55,000 miles. I have been a few rounds with my Check engine light. So far, it is winning. This past weekend, I spent a few hours replacing the knock sensors, the intake gaskets, and the drivers side pre cat O2 sensor. I drove it around for a while that day and have been to town a couple times. However this morning comming to work, 35 miles, the light comes back on. When I get to work, I check the code. This time I got a P0135. I believe this is theO2 heater circuit. Can I test this for 12V with the key on? If I do not get voltage then, Is there a fuse for this, or where does voltage come from.
Thanks,
Paul
just to make sure, you have a 3 wire o2 sensor right? If you do, then yes you can meter for your voltages. Get back to me with your wire count, and colors, and I will tell you which wires you need to meter.... come to think of it... you may hav a 5 wire
1993 K1500 Suburban 350TBI, 378,486KMS on frame, 49,000KMS on Drivetrain. Lots of mods, built for haulin trailers and haulin @$$
2000 K2500 Yukon XL 6.0L Vortec 252000KMS custom CAI, and exhaust...but not done yet.
"If you are dumb enough to do something you don't know how to do, and can't do it safely then WHEN you get hurt its your own fault...BONEHEAD"
If you have the time and energy, and hate electrical stuff as much as i do. Take the corresponding sensor from the other side and flop them, clear the code and start again. If the code changes banks then you know.
Sorry guys for the late responce.I have been on vacation.
i did swap the sensor to the after cat location and the code followed. I have requested a replacement. It was a 4 wire model BTW.
Thanks for your sugestions and help.
Paul
No problem, alwats glad to help.
Bookmarks
