Results 1 to 8 of 8
    Newbie nullifier is a glorious beacon of light
    Apr 2009
    Default Wobbly seats
    OK this is my first post here. I did a search but found nothing so here it is.
    I have a 2002 suburban and my friend has a 2000 silverado we have the same issue with our seats. His passenger seat feels like you will fall out any minute and my driver seat is starting to get this way also. A local mechanic told us this is a fairly common issue with the seat tracks on all GM trucks and the only solution is to replace the whole seat and track assembly.
    I know from other auto forums that there is usually a fix for something that is common so anyone have any ideas on this issue.
    Legend
    ippielb is a name known to all
    Feb 2009
    Canada
    i have this problem on my driver seat, it wiggles forward and backward around a half an inch it feels like, i was thinking about taking it out and tightening every bolt on the assembly.
    2002 Chevrolet Silverado 1500 z71
    6.5" BDS Suspension Lift Key'd to 9"
    5.5" Lift Springs with 4" Blocks
    35" Toyo Open Country Mud Terrain on 18" Ion Alloy 179's
    AirAid Cold Air Intake with K&N Dry Filter & AirAid PowerAid Throttle Body Spacer
    Pacesetter Long Tube Headers with Catalytic Converters Removed and True Dual Exhaust FlowPro Mufflers 4" Stainless Tips
    Bosch +4 Iridium Spark Plugs MSD Ignition Plug Wires
    Innovate LC-1 Wideband o2 Sensor x2
    BDS Dual Steering Stabilizers
    Electric Fan
    4.56 Gears
    EFI Live
    Legend tbplus10 has a reputation beyond repute
    Mar 2007
    -97.0482020 N, 32.6625890 W
    1 Post(s)
    1 Thread(s)
    I had this feeling in the passengers seat on my 97 Suburban. I disassembled the seat track, cleaned it up, and reassembled it. During reassembly I tweaked the seat track with a pair of pliers to it had closer tolerances on the sliders. Havent had a problem since then.
    On a side note werent you on the TTORA board a few years ago?
    I remember someone with the same screen name.
    Tim
    2011 Silverado 1500 LT
    2008 HHR LT
    1999 Tacoma SR5 TRD 4X4
    1993 Jeep Wrangler
    1991 Toyota Rock Crawler
    2009 Harley Davidson Nightrain
    2004 Harley Davidson FLHT "Bagger"
    2003 Glastron GXL Bowrider
    Apr 2009
    Well it is not really a seat bolt issue that we are having. Apparently there is some kind of plastic bushing or spacer that deterioates and makes the screw rod of the power seat develop a fair amount of play. Supposedly this piece is not available and "requires" a full replacement of the seat tracks
  5. #5
    Apr 2009
    Quote Originally Posted by tbplus10 View Post
    Yep I am still a member over there I just rarely log onto it. I mostly hang out on www.Expeditionportal.com . My Burb is my daily and my Tacoma is my trail truck.
  6. #6
    Newbie 6.0gmt800 is a glorious beacon of light
    Mar 2011
    I had this same problem on my 2000 Sierra. A guy on Ebay is selling replacement bushings with instructions for $15. Took me about 4 hours to do both seats and eliminated all the slop in the track. You can find it by typing in GM Power Seat Unwanted Movement/Play Repair kit on Ebay. Hope that helps-
  7. #7
    Jr. Apprentice Uncle Ed is a glorious beacon of light
    Feb 2010
    Deroit, MI
    Groovy! I was going to address this problem in the summer. Now I won't have to fabricate my own blocks.
    Thanks for the tip.
    2002 Tahoe LS 4x4 • 5.3 Flex • Corvette Servo • AVS In-channels • JVC KD-PDR80 • BB Engine Tune • Front Mounted Receiver
    1984 3500 3+3 Crew Cab • 350 w/Edelbrock 600• 700R4 w/Corvette Servo & manual TCC • AVS Surface Mount • JVC w/Sub
  8. #8
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    Had a wobbly seat as well, but mine had actually broke the steel frame of the seat next to the mounting bolts, had it rewelded and no problems.
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
Similar Threads
  1. 2007 TaHOE what seats fit what? PLEASE READ I NEED SOME SEATS ASAP!!!!!!!!!!!!!!
    By leescotty2001 in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 10-29-2009, 11:31 AM
  2. Replies: 0
    Last Post: 08-13-2009, 04:50 AM
  3. i wanna swap bench seats with bucket seats
    By lilt1986 in forum Chevy Truck Accessories
    Last Post: 01-24-2009, 10:31 PM
  4. seats
    By mrsayes in forum Chevy Truck Accessories
    Last Post: 01-20-2009, 08:08 PM
  5. Chirping and wobbly fan [Expired Topic]
    By P.Mikey in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-06-2007, 05:31 PM
