Results 1 to 8 of 8
    Jr. Mechanic Blazerado is a glorious beacon of light
    Apr 2009
    The Dena, Maryland
    Default 4WD question
    I think i'm looking for a unicorn but is there anyway to level the front of a 4wd silverado(04) without touching the torsion bars? Any help is appreciated i havent really started looking yet but i figured i would see if anyone knew first.
    Legend 5speedsilverado is a glorious beacon of light
    Mar 2009
    peoria arizona
    put some weight in the bed, other then that, i dont think their is a way to level them out
    Jr. Mechanic GOTSAND4ME2 is a glorious beacon of light
    Apr 2009
    Ukiah, California
    A buddy of mine read somewhere about air shocks for the front of his 4wd stock truck because he wanted to bring the front end up to level the truck out. I have not done any research for this but it might be a start for you good luck
    Brian
    Nor-Cal
    2000 Chevy Silverado 1500
    6" RCD Lift
    315/75/R16 BFG All Terrains
    Alpine 7" DVD Reciever
    Jbl Componet Door Speakers Front and Rear
    4 10" Jbl Subs
    Led (Blue) Cluster Gauge Blulb Swap
    Dell Studio Hybrid Digital Media Server
    Cobra CB
    Twin Bearcat Scanners
    Jr. Apprentice fredbird is a glorious beacon of light
    Jan 2009
    look into billestien leveling shocks, they have an adjustable ring on them to lift your truck. Helped the neighbor install on his F-150 and it wasn't too difficult. Will cost more and you'll need a good alignment when done, but I don't see why you would have to adjust your torsion bars if you go this route.
    Paul- Maine
    2007 Classic Silverado
    Crew Cab Z-71
    5.3 Flex Fuel V8
    24' Antigua Travel Trailer
  5. #5
    Jr. Engineer Thundare is a glorious beacon of light
    Nov 2008
    Portland Oregon
    Use Air Shocks, They are great! could not be easier. All you need is an air compressor thats it.
    1995 Chevy Silverado
    Fully loaded!!!
    4Wheel Drive
    5.7 Liter
    Blue
    Best Engine In The World!!!!!
    Once i had a nearly dead battery and was only able to get 1 slow crank per attempt, Once to the fifth crank she fired up! (True Story)
    ________________________________________
    Do you have a Tahoe,Yukon or a suburban? Join My Group
    http://www.gmtruckclub.com/forum/group.php?groupid=26
  6. #6
    Legend
    silveradotrailblazer has a reputation beyond repute
    Dec 2008
    Andalusia,Alabama
    Cool 4wd question
    The Bilstein shocks are for 07 (new body style up) . Ive never seen air shocks for the front, I think the rubber bladder would rub. The Suspensionmaxx torsen keys are nice because they have so much adjustment and dont stiffen the ride.
  7. #7
    Jr. Mechanic ukrkoz is a glorious beacon of light
    May 2007
    1. i installed higher end KYBs in the front, raised it my 2 fingers width. no fancy stuff, no nothing. just shocks.
    2. i always drive with counterbalance in the bed. i weigh 265, i have roughly my weight in the far right corner. levels PERFECTLY, corners much better, and ride is softer.
    DON'T FIX IT IF IT AIN'T BROK. IF IT'S BROK - FIX RIGHT AWAY.
    WONNA THINGS DONE RIGHT, DO THEM YOURSELF
    2000 SILVERADO, CENTURION EDITION, 4WD, Z71, 5.3 VORTEC
    NO DUMM MODS
  8. #8
    Apr 2009
    The Dena, Maryland
    Thanks for the advice you guys, i kinda figured there wasnt much i could do without touching the torsion bars. The only thing i dont like about the torsion bars is once you change the angles it starts to wear the cv boots prematurely. Has anyone used those 9 way adjustable rancho shocks for the front?
Similar Threads
  1. Answer question with question game?
    By 1st Synthetics in forum Contests, Giveaways & Games
    Last Post: 11-01-2011, 09:57 PM
