Results 1 to 6 of 6
    Jr. Apprentice 97BurbanSLT is a glorious beacon of light
    Apr 2009
    Default Distributor Re-install ((HELP))
    Hey guys i'm on the backside of my intake manifold gasket repair. Along the way I discoverd a broken distributor so I went and bought a new one and compared them and transferred my marks that noted the location of the rotor and so on. This reman distributor I'm not getting to seat all the way on the gear in the exact location that i had the old one marked at. Is there any reason why i wouldnt be able do re-install this reman distributor in the identical manner that I pulled the old one? Please help I'm trying to get as much possible done tonight as I need my truck back running ASAP. thanks guys.
    ~Phil
    1997 GMC Suburban K2500 SLT AUTO 4x4 7.4litre 454ci. "ALL STOCK" (NO MODS)
    Legend unplugged has a reputation beyond repute
    Sep 2006
    High Deserts of SoCal
    When it won't go back in the way you expected.....move on to the next step: Installation from scratch.
    Here are two good references:
    Classiccarauto.com or pdf file: Streetsideauto.com
    Likely a problem with the oil pump drive lining up.
    There is no way to happiness....happiness is the way.
    http://kx6ijq.blu.livefilestore.com/y1pcOFVNH4ix1hjyGUVyXK5LRfef7qSeWzlZDorpQhIEfkZ2ZA  _vXMYypuKMJFw671uF2ZPhjez_j-atRmcjM2zQKpQi1JSsB75/burb1.JPG
    High Desert SoCal
    93 K1500 burb (personal) 350 AT 3" Lift 250K+
    02 Honda Civic LX
    Looking for a 1990's Miata for an engine swap
    Apr 2009
    I know this may come across as a silly question but couldnt I take a long flathead screwdriver and use it to turn the oil pump drive to where I would want it? Or is that a no no? Just thought I would as bcuz this is new to me. Thanks
    ~Phil
    Jr. Mechanic Blazerado is a glorious beacon of light
    Apr 2009
    The Dena, Maryland
    Alot of times the oil pump drive gear will move when you pull the distributor out. Its not much but its enough to piss you off. Just take a long screwdriver in there and turn the drive gear to desired fitment. Hope this helps.
  5. #5
    Apr 2009
    Sure enough did, when i was working with it at 12:30 last night i had given up considering i had to be at work in 5,1/2 hours and was messin with it for 2hours. Just got home and i have a small pry bar with a 5/8" head and that did the trick to get the oil pump lined up thanks bud you're a life saver.
    ~Phil
  6. #6
    Apr 2009
    The Dena, Maryland
    Anytime man, been there before in a starbucks parking lot installing an intake manifold on a 90 S10 Blazer. Not fun
Similar Threads
  1. Vortec Distributor
    By rusty_buckets in forum General Chevy Tech Q&A
    Last Post: 02-08-2012, 03:39 AM
  2. Distributor help on a 7.4L Vortec
    By rowekmr in forum Powertrain
    Last Post: 12-03-2010, 03:43 AM
  3. Distributor Exchange?
    By mrcaddy in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 03-01-2010, 08:22 AM
  4. Bad Distributor??
    Last Post: 02-11-2010, 04:22 PM
  5. Distributor issue?
    By artlock in forum General Chevy Tech Q&A
    Last Post: 08-17-2009, 08:51 AM
