Results 1 to 3 of 3
    Newbie silver187 is a glorious beacon of light
    Apr 2009
    Default wire isnt hot,
    i have a 89 silverado halfton, its been for a while and im int he middle of restoring it.
    im changing out the stereo and putting in a jensen vm9312 and i took the old amp out and its all connected, but it wont turn on, where does the power wire go to, so i can see if its a dead line or not?
    Jr. Engineer L0sts0ul is a name known to all
    Feb 2007
    Edmonton, Alberta, Canada
    make sure you have the remote wire from your deck hooked up and get a meter to test the fuse or just look at it under the hood for the positive wire.
    if its simply a sub amp then you should have 5 wires hooked up to it.
    pos and neg for power, remote turn on, and pos and neg to sub..
    thats it
    1993 K1500 Suburban 350TBI, 378,486KMS on frame, 49,000KMS on Drivetrain. Lots of mods, built for haulin trailers and haulin @$$
    2000 K2500 Yukon XL 6.0L Vortec 252000KMS custom CAI, and exhaust...but not done yet.
    "If you are dumb enough to do something you don't know how to do, and can't do it safely then WHEN you get hurt its your own fault...BONEHEAD"
    Jr. Mechanic SoundZman is a glorious beacon of light
    Apr 2009
    Santa Clarita, CA
    I agree, sounds like the remote turn on isn't connected or the power fuse is blown. Your power wire should go directly from your battery to the amp with a fuse within 18" of the batter.
    Most amps usually have a power LED that comes on when the amp has power, does yours? Make sure your gains arn't turned all the way down, set them about 1/2.
    If you really want to test the amp and your sure your RCA, power and you have a good ground. You could take a 9v batter to power up the RTO input of the amp and that SHOULD fire it up as long as everything else is correct. I say should because I've never tried this, but in theory it should work.
    Let me know how it work.
    I know this has a few additional devices in it but the idea is the same.
    >>>2003 Suburban K1500 LT<<<
    Currently:
    ~Rear overhead DVD
    ~Orion 600D
    ~ 12" Acoustic Elegance AV12
    ~Hankook ATM DynPro A/T's
    ~Flowmaster exhaust
Similar Threads
  1. Replies: 0
    Last Post: 04-20-2010, 06:40 AM
  2. Can anyone tell me what wire this is?
    By trapper_canada in forum Audio / Video Electrical
    Last Post: 10-29-2009, 01:15 AM
  3. Glad to see everyone on this site isnt a dick
    By ahmitchell1 in forum The Coffee Shop
    Last Post: 09-23-2009, 09:59 AM
  4. 1 wire to 3 wire o2 sensor conversion
    By L0sts0ul in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 06-26-2009, 11:30 PM
  5. where -oh where does this wire go?
    By collinsperformance in forum General Chevy Tech Q&A
    Last Post: 10-06-2008, 02:10 PM
