Results 1 to 2 of 2
    Newbie vbcoach is a glorious beacon of light
    Apr 2009
    Default Refrigerant Leak
    I have had several refrigerant leaks on my '96 Surbruban's A/C System. I have repaired 2 of the 3 leaks. The last one that I can't seem to get stopped is on the high side service valve. There does not seem to be a standard schrader valve inside the the service valve. Do I need to remove the service valve header? Also, are there just o-rings inside that need to be replaced? Someone help!
    Moderator
    GaryL is a glorious beacon of light
    Mar 2006
    The Colony, Tx
    You can buy replacement schrader valves for it, so you don't need to replcace the whole part. I have bought them, but it's been a while. I think I bought them at O'reilly Auto Parts, but I'm not sure.
    You remove them like a normal schrader valve except you need a longer tool, one for a tire will not go deep enough.
    Gary
    99 K 1500 Suburban
    78 Silverado Big 10 w/factory 454
    1977 Formula
    1976 Trans Am
    1980 Honda CB900 Custom
Similar Threads
  1. Replies: 7
    Last Post: 12-20-2010, 02:20 PM
  2. oil leak
    By Jcloud in forum General Chevy Tech Q&A
    Last Post: 04-19-2010, 11:38 AM
  3. Oil leak
    By mattpresley in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-29-2009, 05:11 PM
  4. Oil Leak HELP
    By cchas14 in forum General Chevy Tech Q&A
    Last Post: 06-23-2009, 10:09 AM
  5. Oil Leak
    By makthenif in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 10-30-2007, 07:15 AM
