Results 1 to 10 of 12
    Sr. Apprentice BlackHawk99's Avatar
    Apr 2009
    Grand Blanc, MI
    Default Newb from Michigan!
    Hello from Michigan!
    My wife and I are buying a 1997 Tahoe which we test drove last night. We needed an inexpensive family vehicle and came across this Tahoe. We test drove it and it seemed to drive fine, considering the mileage. It has 212,000 miles, but it drove well. It needs some TLC....so that's why I'm here!
    -- The air conditioning needs to be charged (my brother is in that line of work...no big deal)
    -- The driver's rear door will not open. It seems to be stuck in the locked position.
    -- There's a small coolant leak coming from the tee at the heater core hoses.
    -- Needs a GOOD cleaning. It's pretty filthy now.
    -- There's an alarm system that acts goofy. I'm going to have it uninstalled from the local aftermarket shop.
    But for having 212,000 miles it ran great. The push button 4x4 worked well. All the power windows worked. Cruise, CD player, mirrors, etc. all worked. Transmission shifted well. The 350 still was maintaining 50 lbs. of oil pressure even at a hot idle. The owner bought the truck with 120,000 in 2003 and drove it all around northern MI and only ever had to replace the fuel pump, a/c condensor, a/c evaperator, and a/c compressor.
    I'm getting it for $1,475. Good deal?
    Getting that door open is my main concern for the time being...
    Welcome to the Site! That does sound like a pretty good deal. What part of Michigan are you from? I am in South Lyon, MI.
    Scott Douglass 248-721-1002
    Order online:
    www.1st-synthetics.com
    Apr 2009
    Grand Blanc, MI
    I'm from Grand Blanc. Grand Blanc is about 12 miles southeast of Flint, or 50 miles northwest of Detroit.
    I get to South Lyon every now and then. A friend of the family owns a plumbing company and is based in South Lyon!
    Legend bry2500's Avatar
    Oct 2008
    Gloucester, MA
    welcome to the site!!!
    BRYAN
    "IF YOU DON'T TREAT IT LIKE A TRUCK IT'S JUST A REALLY BIG CAR"
    02' Avalanche 2500 Onyx Black
    8.1L Vortec
    43,000 miles
    Apr 2009
    Grand Blanc, MI
    Thanks! I've been doing some searches for the issues with the 97...
    1997 Chevy Tahoe
    2002 GMC Sonoma
    2000 Pontiac Grand Prix GTP
    1999 Pontiac Firehawk
    1978 Pontiac Trans Am
    Welcome to the site! For the price, it sounds like a good deal. The 350's in those years had problems with leaking intake manifold gasket. My '96 leaked at the back, then shortly after that the water pump failed. The mechanic told me that was common at the time. Good luck with the door, maybe someone on the site can help with the door.
    2010 Z/71 Colorado C/C
    Black 4X4 w/5.3L V8
    2007 Winnebago Adventurer
    w/8.1L Chevy & Allison 6spd.
    Canyon Lake, Texas
    Apr 2009
    Grand Blanc, MI
    I'm assuming the intake gasket has been replaced at some point. 212,000 on the original intake seems unheard of. The intakes on the 3800, 3400 and 3100s all leaked badly too. You were lucky to see 80,000 miles out of those intake gaskets.
    I was able to get the door open last night. The lock was stuck shut. I got the door panel off and worked the rod back and forth. Good as new now!
    Scott
    ΜΟΛΩΝ ΛΑΒΕ
    '94 Chevy Suburban K1500
    3" exhaust w/ aero turbine non-baffled muffler
    CFM Technologies TB spacer
    CB w/ 44" whip antenna
    Moderator
    dwill3015's Avatar
    Jan 2007
    Yacolt, Washington
    Welcome to the site and that sounds like a pretty good deal (esp. since the previous owner paid for those expensive repairs).
    Darcy
    Washington State
    Welcome to the site.
    4.8L Vortec | 6inch Lift | 35'' BFG ALL TERRAINS | K&N Intake | AirRaid Throttle Body Space | 3inch straight pipe dumped at rear axle | BlackBear Tuned | 2 13in JL Audio Subs | 1000watt HD amp, 2.9 cap | Kenwood Dble Din | Gibson Hi Flo Cats | HIDs Hi/Los 55watt 8000k |4.56 gears |
    Last: 03-12-2010, 09:50 AM
  2. I'm a NEWB
    By Deano#4 in forum Member Introductions
    Last: 09-23-2009, 04:20 PM
  3. Newb..
    By cheapbeater in forum Member Introductions
    Last: 01-13-2009, 01:18 PM
  4. Newb Looking at an 05
    By cheapbeater in forum Chevy Silverado Forum (GMC Sierra)
    Last: 01-12-2009, 11:10 PM
  5. newb from ga
    By southernlunatic17 in forum Member Introductions
    Last: 12-30-2008, 12:21 AM
