Results 1 to 9 of 9
    Sr. Apprentice 2000liftdsuburban is a glorious beacon of light
    Apr 2009
    Long island
    Default what are these?
    ok, on the truck( just got the burban )
    and it's the lights next to the turn signal's but under the headlights, it's the lights in the corner closer to the grill..... any ideas?
    also, how bad is it to have a leaky tranny cooler line, its not dumping fluid just leaky a bit.
    also when i make a turn i have a slight clunky noise when i turn either way i beleive. the truck is lifted 6 inches as well idk if thatll help anyone?
    Nothin like a liftd truck goin muddn
    Jr. Mechanic Custom04Chevy is a glorious beacon of light
    Feb 2009
    Ft. Worth, TX
    Quote Originally Posted by 2000liftdsuburban View Post
    I'm fairly certain you are referring to your running lamps. they should be on when the car is in drive unless the headlights are on. Thats what they are on my truck anyway...
    Legend phoebeisis has a brilliant future
    Jun 2006
    River Ridge Louisiana-4 miles W of New Orleans-didn't flood-water stopped 800 yards away.
    Where is it leaking?? Mine leaks at the fittings (new aftermarket radiator, different sized fittings required adaptor) a tiny bit.
    The cooler is integral, and inside the normal radiator- it isn't leaking inside the radiator, right?
    Always depends on how much, and where. Slow leak at fittings- not too big a deal. Leak on a fabric/rubber hose-big deal since it will get worse. Either the oil cooler or the trans cooler has a fully metal hose-the other is a rubber/fabric hose.
    Where and how much?
    And, have you checked your trans fluid level-you have to check while running, I think.
    Charlie
    1998 suburban-
    1/2 ton
    199500 miles
    River
    Ridge,LA
    Apr 2009
    Long island
    well i beleive it's an auxillary one than or an oil cooler not too sure, its on the front of the rad, and its not leakn bad just seems to be leakn at the fittings into the rad lookn thingy.
    other than that it aint too bad, oil/tranny is full.
    as far as the lights go, i have daytime running lights, but it's just the headlights turn on, the lower set of lights look almost like a 3157 bulb.... which would be like a turn signal light thats whats thrown me off i guess.
  5. #5
    Jun 2006
    On my 98 Suburban (-5.7)\ the engine oil cooler is built into the radiator and it and the 2 fittings are on the passengers side- the trans cooler is on the drivers side-built into the main radiator also. Your 5.3? is probably more or less the same.
    I wouldn't worry much about a leak-especially since it leaks so little you can't see it go down on the dipstick over a few hundred miles (and don't since mine is leaking/oozing a little also).
    Mine leaked a bit more initially, but it has slowed to an ooze now.I guess grunge builds up at the leak point,and plugs it up!
    Luck,
    Charlie
    1998 suburban-
    1/2 ton
    199500 miles
    River
    Ridge,LA
  6. #6
    Jr. Mechanic Knucklehead is a glorious beacon of light
    Apr 2009
    Elizabeth city NC , originaly from chesapeake VA
    The lights are your running lights, if you turn or pull ( not sure with the 2000s) your headlight switch between the on and off position it should turn on the yellow lights that resemble turning signals, every car has them. As far as the leak goes , its probably just a loose connection, maybe a quik fit fitting not pushed in all the way or the retaining nut is not seated all the way, none the less seems like a minor problem.
    Life's short... Drive hard!
    1990 GMC Suburban 4x4 w/ jasper 355
    6" Skyjacker suspension lift w/ Interco Trxus sts 36 14.5s
    on Mickey Thompson classic rims, Edelbrock
    intake, K&N 14 x 4 filter, JBA shortys
    Magnaflow exhaust, Pioneer system with
    Dual 12 inch subs... The list goes on!
  7. #7
    Apr 2009
    Long island
    ok as i am now getting more familiar with these trucks i still have more questions.
    when i hit the gas(rev up the motor) just a bit, seems like the idle stays high for a longer period of time than normal....... any ideas/
    also does ne one know how to adjust the torsion bars up front( and would you recommend doin it on your own)
    and..... performance, whats the best/cheaper..... performance mods you can do.
    right now it's got 373 gears, exhaust(no headers) kn filter(no CAI)
  8. #8
    Apr 2009
    Long island
    anyone got ne ideas?
  9. #9
    Jr. Apprentice jester is a glorious beacon of light
    May 2009
    Utah
    To adjust the torsion bars first jack up the front end. follow the torsion bars back and you should find the adjuster bolts. I dont remember which way you turn it but give it a few turns and then do the other side the same amoutn and lower the jack. do this until you are happy with the ride height but if you go too high you will put more tension on your steering components and wear out your ball joints faster.
    As far as cheap mods for power, the cheapest and best to start with is always intake and exhaust but dont expect hue numbers. After that everything gets more expensive
