What are your thoughts on tranny flush with 131k. Its the HD tranny matted to the 454. Ive heard multiple stories like with that manny miles if it aint broke dont fix it. and parts may come loose with a flush and fill. 1995 k2500 burb
I waited too long and the tranny started slipping. I had the shop flush 20 quarts through the system and it shifts better now. I'd say go for it.
There is no way to happiness....happiness is the way.
High Desert SoCal
93 K1500 burb (personal) 350 AT 3" Lift 250K+
02 Honda Civic LX
Looking for a 1990's Miata for an engine swap
I say go for it also..
I have a Ford F53 Mh Factory recommend every 30k to flush the tranny on it. E40D problem tranny anyway.
I say do it. I work at a Jiffy Lube and at a Speedee and we do flushes and/or T-techs to transmissions with many more miles than that, and I've only heard of one of them having some sort of problem later on (probably b/c the guy who did it was an idiot).
What I would is pull the pan and change the filter first. You might consider opening the old filter and looking inside. This will tell you straight up the condition of your transmission. Once you have a new filter installed then go ahead and flush it. It may take 20 quarts if the fluid is real dirty. Remember if there is a lot of friction material in the filter then flushing all the old oil out will cause your transmission to fail sooner than if you just leave it alone. There's a good reason why this happens. If you leave it alone it will fail when it fails. The detergents in the new oil will melt all the varnish and crud inside the transmission, valve body and torque converter. This sludge will quickly plug up your new filter and the party's over in short order.
Bottom line is if your filter is full of fine metal and or friction material you can fix it now or have it towed in during your vacation in the mountains. Your choice.![]()
Jim
2004 SILVERADO 2500HD LS
Pro Comp Leveling Kit
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1967 Landcruiser <350 Chevy>
1970 Camaro
1990 Geo Metro Convertible
2007 FJ Cruiser
thanks for the info will do it next week
Here is some good instructions to follow.
http://www.amsoil.com/faqs/atf_and_f...pdf?z0=1695636
2008 GMC Sierra 2500HD Ex. Cab, Fire Red, 6.6L Duramax LMM Equipped with UTG Rocker Pods
AMSOIL is the only oil company that...,"Recommends 25,000 mile oil changes","Gives up to four times better wear protection","Warranties your engine against oil related failure"
Preferred Customers Save up to 30% Click here!!!
Executive Direct Jobber ZO# 1695636
Scott Douglass 248-721-1002
Order online: www.1st-synthetics.com
Bookmarks
