This is my 1st post.............
I just bought a 1988 Silverado Burb. The front end seems higher than the rear end. Is this normal? There is much more clearance between the tire and fender in the front, which might be causing an illusion - but - I also measured from the running board to the ground in front and in the back, and there is an inch difference. I used to have a 2004 and it seemed level.
Thanks, Tom
PS - The front end has 2 shocks per side, and the back end has only 1 shock per side.
The fender wells contribute to this illusion and the shape/slope of the stripe (Assuming your's has two tone factory style paint) does also.
1991 Chevy Suburban, 4 inch lift.
Sounds like your burb doesn't have stock suspension. If you have gas shocks, it could add a little lift.
"Rake" is more a function of taste anyway. Some like 'em level, some like 'em higher on one end or the other.
Adjust yours to match your preference.
The baja type "look" has the appearance of a higher front end.
There is no way to happiness....happiness is the way.
High Desert SoCal
93 K1500 burb (personal) 350 AT 3" Lift 250K+
02 Honda Civic LX
Looking for a 1990's Miata for an engine swap
sounds normal to me. My 1995 burb sagged in the rear like crazy. If the previous owner towed with it a lot the leafs could be flattened out in the rear. A new set of leaves, an add a leaf, or a block (last resort) may fix the problem![]()
Dan
1999 GMC Sierra 2500 350 vortec
1967 Jeep M725 ambulance 230 tornado
1990 Cherokee Limited- 3 inch lift on 33's
...and every one of em has issues
If you have any questions or problems don't hesitate to send me or any other GMTC moderators a PM
Mine was that way , 1990, I add a leaf to the rear...much better
Semper Fi
1990 1500 Suburban 6.2L Diesel 4x4
I have a 1990 Sub' that sits lower at the rear. Planning to add a leaf.
1990 Chevy Suburban V1500 4x4 "Church Bus"
5.7L TBI
3" lift - 35" tires
WARN Manual Locking Hubs
Two up front and one in the rear IS from the factory and yes they will sag but just put a block or add a leaf in the rear, even from the factory they had a very slight sag. Parents had a couple from the 88-91 era and they were both like that brand new
5.7 K&N & True Dual Exhaust
Hypertech III
05 17" Silverado rims
99 LS 1500 5.3 "THE MULE"
Reg Cab Long Box
285/75/16E Dunlop Rover M/T
___________________________
Jason
Thanks for all the replies - I do prefer it more level. Is adding a block or leaf something worth tackling in the driveway, or should I have it done by a shop?
Tom
Never done leafs but heard they can be a pain to line back up if they come loose from the bundle, a small block is pretty easy though
Hypertech III
Reg Cab Long Box
Jason
What is the procedure for installing blocks, and are there choices of blocks?
Bookmarks
