GM Truck Club
Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
  1. #21
    Quote Originally Posted by Dr_Zero View Post
    I think that Autozone and Advance Auto are still allowed to read the code for your in Cali but I have heard they cant clear any codes, seems the shops complained they werent getting the diagnostic fees they are used to ripping you off for.
    If you have to spend more than $30 consider getting yourself a code scanner they can be had for around $40 for a basic model
    This one has OBDII and CAN for the newer vehicles
    Amazon.com: Autel MaxiScan MS300 CAN OBD-II Code Reader: Automotive
    harbor freight has a clone also around $40
    http://www.harborfreight.com/cpi/cta...emnumber=94169
    This is the one I got since it not only shows the code it tells you what it means without having to look it up, its all there on the screen
    Amazon.com: Autel MaxiScan MS409 OBD-II/EOBD Scanner: Automotive
    What you say about clearing codes is very true. There's a good reason why. When a code sets the computer goes into failsafe to protect the engine or transmission. Example: The transmission is slipping because it has a slow leak that went unnoticed until the fluid got too low. Back in the old days you would continue to drive your car until you burned up the clutches. Now the computer turns on the light, jacks up the line pressure, and disables shifting. This forces you to take your car in to get it fixed. Just clearing the code can cause more damage.
    The same holds true for an engine code. Example: Your engine is pinging because of lean condition. The computer sees this and retards the timing. Your check engine light comes on and your truck runs like crap. This forces you to take it in and have it fixed. Clearing the code can just cause more damage.
    As far as code readers go if you are going to buy one, spend the extra money and get one that has DATA. Without any data all you can do is read and clear codes. You canít see what the suspect sensor is doing and without the DATA you just canít find and fix the problem.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
  2. #22
    Quote Originally Posted by dr_zero View Post
    doh! Obd 1 missed that here try this instead
    http://www.troublecodes.net/gm/
    http://www.instructables.com/id/how-...gine-light-fo/
    take a jumper wire and jump it with the key off from the test terminal to the ground terminal the two upper right plug holes then turn the key on do not start it!!!!! Then the service engine soon light will flash code 12 it will be one flash a short pause then two flashes after another slightly longer pause the code will repeat itself two more times that says the diagnostic syatem is working if there is nothng wrong 12 will repeat itself over and over but if there is a problem it will flash the code 3 times then code 12 3 times and the next code if there is more than 1 code stored
    for other folks
    i think that autozone and advance auto are still allowed to read the code for your in cali but i have heard they cant clear any codes, seems the shops complained they werent getting the diagnostic fees they are used to ripping you off for.
    this one has obdii and can for the newer vehicles
    amazon.com: Autel maxiscan ms300 can obd-ii code reader: Automotive
    this is the one i got since it not only shows the code it tells you what it means without having to look it up, its all there on the screen
    amazon.com: Autel maxiscan ms409 obd-ii/eobd scanner: Automotive
    thanks for the great advice, ill give it a try and let you know how it works out
    90' Chevy Silverado 1500
    Suspension: Belltech 2" Drop Spindles
    Paint/Body: Silver Metalic w/ Red & White pinstriping, steel cowl induction hood, custom billet grille
    Interior/Electronics: Under Construction
    Wheels/Tires: American Racing Chrome Baja 17x8 / Wrapped in TOYO Proxes ST II
    Engine/Trans/Perf: EFI 5.7 Liter 350 cid V-8 w/ 700R4 Trans.
    K&N 57 Series FIPK II CAI
    40 series Flows
    HOORAH SEABEE's!! :fighting0037:SHOOT TO KILL!!
Similar Threads
  1. exhaust emissions 84 C-10
    By oletrkguy in forum Lifted & Offroad Suspension
    Last Post: 04-28-2010, 08:15 PM
  2. Failed inspection
    By ahm1127 in forum General Chevy & GM Tech Questions
    Last Post: 01-04-2010, 11:05 AM
  3. Evap Emissions?
    By BigJosh in forum General Chevy & GM Tech Questions
    Last Post: 09-27-2009, 02:53 PM
  4. Didn't pass emissions
    By jprimrose4292 in forum General Chevy & GM Tech Questions
    Last Post: 04-13-2009, 12:52 AM
  5. emissions problems....
    By Rob in forum Chevy C/K Truck Forum
    Last Post: 06-28-2008, 11:54 PM
