Results 1 to 10 of 22
    Default I failed my emissions testing today!
    Today I went to get my truck (signature pic) emissions checked which is required every other year here in Ohio, so I am thinking no problem passing because the truck has only 9,500 miles and is in awesome condition. Well I pulled up and they did the gas pressure check and it passed, and then they pulled the truck forward and proceeded to put the OBD II scanner on it to check for codes or any problems. The next thing I know the guy is asking me if I have done any modification or engine upgrades such as a tuner or something like that, I told him absolutely not even though I had taken my Hyperpac off of it prior to leaving the house. He said that it had failed because the system had been completely erased by someone, so I stood there thinking about what I had done wrong to fail this test and then it occured to me. I told him I had a cut off switch for when I put the truck in storage for the winter to keep it from dying, then the guy tells me that every time I disconnected that battery it is erasing all of the codes and that it takes time for the computer to relearn all of the driving conditions such as o2 temps, egr valve, basically everything on the truck. I had only ran the truck about 20 miles before going up to the emissions place so It didn't have time to relearn I guess, he then gives me the option to run an RPM test which I had never heard of so I agreed to it. They put the truck in neutral and revved it up to what sounded like 5,000 RPM's and then they let off completely and just shut it off right away, which I wasn't too happy with them doing that to my truck!
    IT PASSED FINALLY! They threw out the results for the failed computer test, and they gave me a pass slip for the RPM test and I was able to get my license plates afterwards. I am going to have the same problem with my S-10 too, because I have a disconnect on it too to keep the battery from draining. So if you have a battery disconnect on your newer vehicle, run it for at least a week before you take it to the emissions station because it won't pass! Call me a dummy but I didn't know that the cut-off would mess with the computer like that, but I have to have the disconnect otherwise I will go through about 2 batteries a year from my lights.
    Here's a pic f the disconnect by the way, in case you were curious.
    TrailLeadr's Avatar
    Jun 2005
    Coventry, Rhode Island
    I recently ran into the same situation. We had a bad knock sensor on the Avalanche, and after I replaced it I had to erase the code because it wasn't going away on it's own. I initially failed because the comp wasn't ready to be tested. So after a 30mile run to get McDonalds for lunch with my son, the truck passed.
    Live and learn. But very good advice.
    Patrick
    Rhode Island
    They do the testing differently here in Nevada as well as in California. The way it works here is if there are any incomplete monitors the test is aborted. You are instructed that there are incomplete OBD checks and you need to drive the vehicle until the monitor clears or the code returns. This prevents you from clearing a code and immediately trying to get a smog.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    I am glad we do not have any of that testing here in Michigan.
    Scott Douglass 248-721-1002
    Order online:
    www.1st-synthetics.com
    My friends with their mustangs have had this problem in the past. They use their programmer to clear the codes for the 02 sensor after the cats (which they removed). then they usually have to go back to get re tested. Some of the guys at the emissions place knew what they did. I've been through the rev test several times, my jeep stalled out twice while on the rollers, but still managed to pass
    Dan
    1999 GMC Sierra 2500 350 vortec
    1967 Jeep M725 ambulance 230 tornado
    1990 Cherokee Limited- 3 inch lift on 33's
    ...and every one of em has issues
    If you have any questions or problems don't hesitate to send me or any other GMTC moderators a PM
    HA, here i mississippi when i have to get my inspection sticker renewed all they check is for tinted windows!!!THATS IT!!! no stupid tests or checking the condition of the truck. takes 30 seconds and im outta there!!
    Scott-Mississippi
    1996 Silverado
    *Mostly stock for now
    *Soon to be airbag project..
    Quote Originally Posted by 1st Synthetics View Post
    The new testing machines just won't let you cheat anymore. A couple of years ago you could take your rig to a smog shop and they could cheat the system although it was illegal. What they would do is hook the OBD link up to your vehicle and the sniffer into another unmodified vehicle. Your vehicle would pass with flying colors.....Now you can't do that anymore because the new machines use the on board sensors to perform the test. No more sniffer in the tail pipe. The "sniffing" is done with the O2 sensors on your truck along with your vehicles computer.
    Remember what starts in California starts working it's way EAST so get ready!
    Texas has pretty bad air in the heat of the summer, so the testing has gotten more involved each few years. I did the same thing maybe 6 or 8 years ago with a bad O2 sensor, hoping to reset everything except the bad O2, I couldn't find the sweet spot, so I changed the O2 and run her a hundred miles and then passed after that.
    Steve
    10 Chevy Traverse LT AWD
    Legend bry2500's Avatar
    Oct 2008
    Gloucester, MA
    Tests here in Mass are the same . No codes No sticker. Very simple math. Unless you know someone ( which is illegal) anything outside the lines is an instant rejection.
    My wifes van just failed for tires. They said that they were too close to the wear indicators and they. @ $225 a tire it was a hard pill to swallow.
    BRYAN
    "IF YOU DON'T TREAT IT LIKE A TRUCK IT'S JUST A REALLY BIG CAR"
    02' Avalanche 2500 Onyx Black
    8.1L Vortec
    43,000 miles
    Quote Originally Posted by Jimmiee View Post
    I am waiting for the day that everyone has to pass California emissions, then I think a lot of people will be buying new exhaust systems and doing a lot of engine downgrading. I don't understand this either Diesel trucks do not get emissions tested here, so I guess I should have bought a diesel! I had never heard about using the unmodified vehicle to get the modified one to pass, that is pretty slick although like you said they have figured that one out now. A while back when I was at the Chevy dealer they offered me a 2007 Corvette Z06 hardtop for $38,000 new, and when I asked him what was wrong with it he said no one wanted it because of the California emissions package on it. They had gotten it from a dealer trade and they got stuck with it, does anybody know exactly what the California emissions package is on a vehicle?
  1. exhaust emissions 84 C-10
    By oletrkguy in forum Lifted & Offroad Suspension
    Last: 04-28-2010, 08:15 PM
  2. Failed inspection
    By ahm1127 in forum General Chevy & GM Tech Questions
    Last: 01-04-2010, 11:05 AM
  3. Evap Emissions?
    By BigJosh in forum General Chevy & GM Tech Questions
    Last: 09-27-2009, 02:53 PM
  4. Didn't pass emissions
    By jprimrose4292 in forum General Chevy & GM Tech Questions
    Last: 04-13-2009, 12:52 AM
  5. emissions problems....
    By Rob in forum Chevy C/K Truck Forum
    Last: 06-28-2008, 11:54 PM
