    Default Oil pump replacement question
    I was wondering if someone may be able to let me know if it is possible to change to oil pump in a 2001 silverado 2500 4x4? I have a 01 with 366,000 miles, the oil pressure tends to be fine then drops off then comes back up. The sending unit is fine, so ive been advised that a new oil pump in in order.
    Any help would be apreciated very much.
    Thanks, Steve
    have the same issue and my mechanic said not to bother with the pump, that with high mileage its more then likely its a bearing within the engine that is allowing oil to get by, he said as long as its holding decent pressure when driving, not overheating, and no metal in the oil not to worry. He did say that if you do want to change the pump you have to remove the front drive shaft and any tranny or oil coolant lies to get the oil pan off
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    Mar 2009
    Brooklyn, NY
    probably not the oil pump. I've just gone through this myself. My motor had 150k miles and low oil ressure. Swapped a high-flow pump (not a small job there) and no change.
    Old motors wear out mains and just don't hold pressure.
    I ended up swappung in a new motor with 10K miles and oil pressure is a-OK.
    No cheap solution there.
  1. Fuel Pump Replacement
    By jrozalez in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 01-16-2010, 02:17 PM
  2. water pump replacement
    By bowtiebrian in forum General Chevy & GM Tech Questions
    Last Post: 04-28-2009, 12:07 PM
  3. Oil Pump replacement?
    By vanimal in forum GM Powertrain
    Last Post: 01-06-2009, 10:52 AM
  4. Was looking at the How-To on fuel pump replacement.. quick question:
    By Springthing in forum General Chevy & GM Tech Questions
    Last Post: 09-17-2008, 12:53 PM
  5. P/S pump replacement
    By collinsperformance in forum GM Powertrain
    Last Post: 01-05-2008, 08:22 PM
