Results 1 to 2 of 2
    Dec 2010
    Groton, Connecticut, United States
    Default IFS to Solid Axle Conversion
    Ok, new thing I'm looking into is a Solid Axle Swap. I can't seem to find any kits for a 1999 1/2 1500 4wd. Any body know anything about this? I'm just starting to do research about it, so I am looking for info on compatible axles and bracket systems. I already have a 6" rough country NTD lift kit on the truck, but I've had nothing but issues with my IFS and want to swap over to a solid axle. Based on the amount of fabrication work required, I'll probably have it done by a shop, but if I can find an axle, and brackets and everything I need online, I may do it in my garage. I run 35" Nitto Mud Grapplers right now, and any info would be helpful. Thanks guys!
    1999 Silverado 1500 LS Ext Cab Z71 5.3L
    6" Rough Country NTD Suspension lift kit, 16" Vision Warrior wheels, 35" Nitto Mud Grapplers, Cat-back dual exhaust, CAI, chrome step rails, auxiliary off-road lights. More to follow...
    Try googling "solid axle swap kits" for 1988 to 2013 1/2 ton trucks I found over 30 kits.
    Ive used ORU kits before and their probably one of the most complete.
    I suspect sticker shock will slow your project down some, if you have the fab skills to do this job the cheapest Ive seen it done is around $2500, with a shop doing the work expect something in the range of $5000 to $6000.
    Most kits supply brackets, springs, the hardware peices, you need to supply axle and T case.
    The most popular axle used for this swap is the Dana 44 with a left hand drop, found in older Ford and Dodge 1/2 ton trucks, the most popular axle wanted for this swap is the Dana 60 found in older Ford and Dodge 3/4 ton trucks, unfortunately the price of a good Dana 60 is steep which is why most plans get changed.
  1. 2005 Duramax solid front axle conversion....need help
    By meanirsk in forum Lifted & Offroad Suspension
    Last Post: 07-08-2012, 07:11 PM
  2. Solid front axle conversion
    By Brigham in forum Chevy C/K Truck Forum
    Last Post: 09-23-2011, 10:35 AM
  3. 1994 Suburban Solid Axle Conversion Leaf Springs ?????
    By Campanella Customs in forum Member Introductions
    Last Post: 11-02-2010, 12:49 AM
  4. solid axle conversion
    By white_nasty04 in forum Lifted & Offroad Suspension
    Last Post: 07-30-2009, 09:44 PM
  5. Solid Axle Swap
    By ig109 in forum Chevy Truck Accessories
    Last Post: 02-11-2009, 11:23 AM
