Results 1 to 8 of 8
    Newbie aberlin is a glorious beacon of light
    May 2009
    Default Rough idle when using air and accessories
    Hey guys,
    I have a 1990 Suburban 2500 5.7 V8 4x4.
    Just got a tune up including new wires, spark plugs, cap rotor etc.
    multiple vacuum leaks fixed.
    I have to let the car warm up for about 5 minutes or else it sputters under the load of the trans being engaged. Also when in park, or drive, if the air conditioning is on it starts to sputter wanting to stall. I also noticed when headlights are on, it wants to stall when idling. Runs perfect when on the gas pedal.
    Any suggestions? Is there an Idle up valve? is there idle speed adjustment? what should i be looking at.
    Thanks,
    Alex
    Jr. Engineer L0sts0ul is a name known to all
    Feb 2007
    Edmonton, Alberta, Canada
    dirty injectors? fuel filter? Air filter? PCV valve? fuel pump, and or pressure?
    lots to look at for this problem.
    you have TBI setup right? or are you carb?
    1993 K1500 Suburban 350TBI, 378,486KMS on frame, 49,000KMS on Drivetrain. Lots of mods, built for haulin trailers and haulin @$$
    2000 K2500 Yukon XL 6.0L Vortec 252000KMS custom CAI, and exhaust...but not done yet.
    "If you are dumb enough to do something you don't know how to do, and can't do it safely then WHEN you get hurt its your own fault...BONEHEAD"
    Legend
    silveradotrailblazer has a reputation beyond repute
    Dec 2008
    Andalusia,Alabama
    Cool Rough idle when using air and accessories
    I would take off the throttle body and clean with a good throttle body cleaner (CRC works well) and take out the idle control valve and clean, they get carboned up and wont move in and out. Also check out your altenator.
    Jr. Apprentice opusd2 is a glorious beacon of light
    Dec 2008
    Check your ecm in the distributor to see if the timing is off. It the problem usually happens under load, chances are it's a timing issue
  5. #5
    Jr. Apprentice wolfie is a glorious beacon of light
    May 2009
    arizona
    Default Electrical?
    I have had a similar issue in a chevy car. the fix for me was new alternator and cleaning the wires on the battery for better current flow. if the alternator isn't bad you could try checking out its nearest components in the electrical system. other than that I'm just not sure. wish i could be of more help.
    2000 silverado 1500
    extended cab, long bed
    5.3 V-8, k&n air filter
    GM step bar (long)
    Tow package, 2WD
    MINT CONDITION!!
  6. #6
    May 2009
    I have new wires, new fuel filter, new fuel pump, new plugs, new cap and rotor, it is not carborated. I think I'll start with the throttle body cleaning and the idle valve. hopefully that does something.
  7. #7
    Master Mechanic daddytech is a glorious beacon of light
    Mar 2008
    Portland TN
    need to start with the fuel filter and work your way up from there , could also be the fuel pump not delivering enough fuel to the carb. Might also try running some Seafoam through the brake booster vacuum line , run the whole can through it , the truck will smoke a while but when it's done you should notice a big difference.
  8. #8
    Sr. Apprentice RWK is a name known to all
    Mar 2009
    Alaska
    The idle problem on my car was fixed with a new Idle Air Control Valve. The old valve would extend out and not retract. When you turn on the A/C, the IAC Valve should bump up the idle a little.
Similar Threads
  1. rough idle with a/c
    By willardearl76 in forum General Chevy Tech Q&A
    Last Post: 04-07-2010, 10:38 AM
  2. Rough Idle..
    By willbradfan in forum Powertrain
    Last Post: 05-07-2009, 11:19 PM
  3. rough idle
    By RLawns in forum General Chevy Tech Q&A
    Last Post: 02-03-2009, 01:11 PM
  4. rough idle
    By niteruner in forum Chevy Colorado Forum (GMC Canyon)
    Last Post: 12-09-2007, 08:12 PM
  5. rough idle
    By L0sts0ul in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 02-25-2007, 08:38 PM
