Thread: AC question
    Default AC question
    89 Suburban. AC has not been charged in 7 years. I know this is grasping straws, but could there be a chance I could just try to recharge it and have it work? Or should I just accept that the seals are shot, and go ahead and try to find a new unit? Would it be worth it to even attempt to look at a pull yard for an AC unit?
    Thanks
    You should be aboe to run a pressure check on the system I would think, otherwise a can is usually around $15-20 to recharge the A/C. So even if it doesnt hold it its not too much money wasted. More then likely after seven years of no use and no charge everything has dried up
    Hypertech III, K&N, true dual
    285/75/16
    ___________________________
    Jason
    Jr. Mechanic Blazerado's Avatar
    Apr 2009
    The Dena, Maryland
    If you know anyone who works at a shop and has an AC machine now would be the time to talk to them. After throwing a can of freon into it, it might not work still due to lack of vacuum on the system prior to charge.
    If any air entered your system a recharge is a waste of money. There will be scale that will flake off and plug up the system. Take it to someone for an estimate. They will probably charge it up to see what's wrong anyway before giving you an estimate.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
    ID bet after that long the orings are junk....
  1. Answer question with question game?
    By 1st Synthetics in forum Games Forum
    Last: 11-01-2011, 08:57 PM
