Results 1 to 9 of 9
    Jr. Apprentice 92 Burban is a glorious beacon of light
    Feb 2008
    Las Vegas, Nv
    Default Transfer case issue ?????
    Help!!!
    Well I was driving home from work the other night when the burban started sounding like a jack hammer. I thought it was the rear end but I put it in 4wd & pulled the rear drive shaft & it would not go anywhere & made a high pitch noise. I put the shaft back in & it would go forward & backword but it still clunks.
    Am I on the right track??? Any thing else I could check????? Where can I get a replacement?
    Legend bry2500 is a glorious beacon of light
    Oct 2008
    Gloucester, MA
    My 02 Avalanche is making the same noise. I just noticed it as I went from one building at work to the other. I hope it's not the t'case. I'm hoping low on fluid in the front diff or t'case. i can't afford to replace one right now. I'm hoping it the early signs of a ujoint even.
    BRYAN
    "IF YOU DON'T TREAT IT LIKE A TRUCK IT'S JUST A REALLY BIG CAR"
    02' Avalanche 2500 Onyx Black
    8.1L Vortec
    43,000 miles
    Jr. Mechanic TUTONE is a glorious beacon of light
    Apr 2009
    Southern Ohio
    Default Clunking
    Could be the planetary gear going out in the tranny. My '90 burb did the same thing. Had the tranny rebuilt and changed the lockout hubs immediately afterwards. Mine had the automatic locking hubs and I don't think they were unlocking all the way which is bad for the drivetrain driving 20 miles to work at 65 mph every day. I haven't had a problem since. I'm not sure if the hubs caused the damage to the tranny or not but I wasn't taking any chances so I changed them. Besides, I like having the control of the manual hubs more than the automatic hubs. "If you want something done right [like unlocking your hubs] do it yourself." Changing the lockouts was actually pretty simple too. If you do decide to change your lockout hubs, check your wheel bearing nuts and bearings while you're at it. Make sure they're properly torqued and greased. My front passenger side bearing was quite loose.
    1990 Chevy Suburban V1500 4x4 "Church Bus"
    5.7L TBI
    3" lift - 35" tires
    WARN Manual Locking Hubs
    Oct 2008
    Gloucester, MA
    went under the truck yesterday and found that the front drive shaft u joint to the transfer case was nearly in 2 pieces. got 2 u joints now just need nice weather to do the job. I hope this is my noise and not anything else. I am gonna pull the shaft and drive around without it to see.
    I hope you have an easy fix on your hands too.
    BRYAN
    8.1L Vortec
    43,000 miles
  5. #5
    Feb 2008
    Las Vegas, Nv
    Well I have disassembeled the case and I cannot see any obvious signs of what was banging around. Has anyone had a problem with the trans chain streaching? Would the range fork pads moving cause the noise? I was hoping for an obvious sign but its never that easy.
  6. #6
    Legend 2COR517 has a reputation beyond repute
    May 2009
    Maine
    Quote Originally Posted by TUTONE View Post
    Even if the auto hubs didn't unlock, it wouldn't have any impact on the transmission if the case is in 2wd.
    As for bad for the drivetrain, that's very debatable. GM and others had full time 4wd on many vehicles for many years. You couldn't unlock the hubs on them if you wanted to. And the newer autotrac cases have the entire front drivetrain rotating all the time.
  7. #7
    Feb 2008
    Las Vegas, Nv
    I have read that the Transfer case chain can stretch and bang in the case. Could this be it? The U joints look good old but good. I was thinking about putting the case together without the chain and checking it. But I'm not sure what to do.
  8. #8
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    The chain would only make noise in 4WD. In 2WD the chain is not turning or if it is it's just going along for the ride.
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
  9. #9
    Feb 2008
    Las Vegas, Nv
    Thanks All,
    I think the noise is in the rear end & thats what I will be looking at next.
    Also the NP241 is easy to rebuild as long as you know what end of the socket the bolt fits you will be fine & it can be done still in the truck. If anyone need help I can walk you through it.
Similar Threads
  1. Transfer Case issue
    By rpm0044 in forum Powertrain
    Last Post: 05-12-2010, 11:07 AM
  2. transfer case issue?
    By dsfloyd in forum Powertrain
    Last Post: 10-29-2009, 05:24 PM
  3. 96 gm transfer case issue
    By DMAXX2007 in forum Powertrain
    Last Post: 05-06-2009, 10:38 PM
  4. 96 transfer case
    By desertratt66@yahoo.com in forum Powertrain
    Last Post: 04-05-2009, 12:17 PM
  5. 1992 Suburban transfer case issue
    By bracketracer-78 in forum Powertrain
    Last Post: 08-17-2007, 09:23 AM
