Results 1 to 9 of 9
    Jr. Apprentice jrstroh_96 is a glorious beacon of light
    May 2009
    Default help grinding brakes making me looney
    Hello, i came here cause every person i know is lost and im tired of spending money.I have a 92 K1500 ext gmc. Sitting on 6-inch lift and 35's. I bought the truck last january. I have had this lovely grinding sound coming from both front brakes and a pull to the left. so i replaced the left wheel bearing, both sides rotor calipers and pads. figured that would work, nope.Replaced brake lines, still nope. The sound is weird before i replaced bearing it would go away if i made hard sharp turns either left or right no it dont do that. But now it gets weirdier. When coming to a stop they grind as if, i'm metal to metal. Then they stop and dont start grinding again until around 300 yards to a quarter of a mile down the road. Sometimes it grinds like i have a warped rotors but then theres times it dont stop. This goes on at all speeds. Now im thinking its the proportioning value, but the local dealer wants 271.99 for a new one, and local salvage yards cant look up this code of JB5 that my truck has for brakes and from what the dealer tells me is only in K series 1992-1994. So im lost, please someone help.
    Jr. Apprentice Klon is a glorious beacon of light
    Apr 2009
    Phoenix, AZ
    there is no way its the proportioning valve. be sure to check the rear brakes and verify. i am a mechanic. dont waste your money. its something else.
    May 2009
    Thanks I'm going to check and see if the lift kit i still tighten and then take it to a alignment shop again. and see where im at from there
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    A warped rotor wont give you grinding it will be vibrating and excessive pulsating when braking. I would pull the front rotors and take them to a shop, even some oreillys and autozone can resurface rotors if they need to be done, have them give them a check. Just because brake parts are new doesnt mean they are true. I would also check your cv axles up front.
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
  5. #5
    Legend tbplus10 has a reputation beyond repute
    Mar 2007
    -97.0482020 N, 32.6625890 W
    1 Post(s)
    1 Thread(s)
    Check the inside of the front rims, is it possible you have a wheel rubbing the caliper or something on the suspension?
    I've seen this happen when you change to wider wheels, and I'm guessing when it was lifted they did it to put on wider wheels and tires.
    Tim
    2011 Silverado 1500 LT
    2008 HHR LT
    1999 Tacoma SR5 TRD 4X4
    1993 Jeep Wrangler
    1991 Toyota Rock Crawler
    2009 Harley Davidson Nightrain
    2004 Harley Davidson FLHT "Bagger"
    2003 Glastron GXL Bowrider
  6. #6
    May 2009
    ok what am i looking for on the cv shafts and i still have the stock rims on the truck
  7. #7
    Feb 2008
    1 Post(s)
    Look around the boots of the cv axles, are they leaking any think fluid, or cut. Grab a hold with both hands of the boot and shake it, maybe the joint inside broke.
    Hypertech III
    Reg Cab Long Box
    Jason
  8. #8
    May 2009
    ok thanks i did find that my left side tie rods shot and just replaced both sides last year.
  9. #9
    May 2009
    Finally figured it out. The ball joints, tie rods and upper bushing was shot. And the grinding was the dust coverrubbing on the backside of the rotor. All done and quiet.
Similar Threads
  1. NP 261 grinding problem
    By 2500HD4x4 in forum Powertrain
    Last Post: 05-12-2010, 04:52 AM
  2. 1500 brakes vs 2500 brakes
    By nos351wcm in forum Lifted & Offroad Suspension
    Last Post: 04-14-2010, 01:42 AM
  3. Intermittent Grinding
    By KC8QVO in forum Powertrain
    Last Post: 12-15-2009, 10:27 AM
  4. Grinding in first, second, and over bumps???
    By 1995ChevyHoe in forum Powertrain
    Last Post: 11-22-2009, 06:42 PM
  5. grinding noises
    By NC06silverado in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 04-02-2007, 09:03 AM
