Hi Folks,
I have a 2000 Silverado with 100,000 miles on a 5.3 engine. Lately my fuel gauge bounces around even after filling the tank it often goes to empty. My 2000 Corvette does the same so what is it with Chevy sending units? Anyone else have this problem, if so, cna you pass on what you did to fix it. Thanks.
Dan
Welcome to the site, Dan. I have not heard of this problem, before. My '04 has 120,000+ it w/o any problem. I'm sure if it is a "common" problem, you'll get some inlput.
2010 Z/71 Colorado C/C
Black 4X4 w/5.3L V8
2007 Winnebago Adventurer
w/8.1L Chevy & Allison 6spd.
Canyon Lake, Texas
if you just totally can't stand it, slide truck bed back to clear tank and replace pump and sending unit. while you there. pumps fail on those sooner than later anyway.
DON'T FIX IT IF IT AIN'T BROK. IF IT'S BROK - FIX RIGHT AWAY.
WONNA THINGS DONE RIGHT, DO THEM YOURSELF
2000 SILVERADO, CENTURION EDITION, 4WD, Z71, 5.3 VORTEC
NO DUMM MODS
On my '98 dodge i used to have we found it was easier to drop the fuel tank rather than slide the bed back. Chevy's might be different. If you do replace the unit or pump make sure you do it when the tank is near empty. It makes it alot easier. Good luck.
Mike - OREGON
2001 chevy silverado 4x4. 5.3L, 6 inch Fabtech lift, 35" Toyo MT's, 17" Weld Racing wheels, arma coating on rocker panels. No exhaust after cat. Pioneer stereo
you are correct, it is the sending unit, but the bad thing about that, is that the sending unit and the fuel pump are all in one part. i am on my 4th one. im not going into details b/c its way too much to type, and it is posted here in about 4 different places. long story short, AC DELCO!!!!! DO NOT GO THE CHEAP ROUTE and get some off brand, do not listen to the guy behind the counter when he tells you that a fuel pump is a fuel pump because they arent!
2000 silverado with a 5.3l v8, shorty headers, upgraded plugs, 10 mil wires, magnaflow high flow cats, flowmaster 80 series muffler(2 in 2 out) w/ 18 inch stainless silverline tips. i have a k&n CIA. its a 4x4 z71 offroad package. Ls model.
extended cab 160k miles, truxedo low profile bed cover, diablo sport predator tuner.
reman tranny @ 130k miles
Chris
not sure on truck but I hav 97 C5 Corvette that had same prob.. very common with C5's.. easy solution.. go to www.zip-corvette.com and get 1 bottle BG44k fuel additive.. Run ur Vette tank empty then put in that bottle and fill tank with Chevron fuel ... Cause of prob is running cheap gas.. Use Chevron ONLY.. trust me it works.. My prob disappeared immediately.. somehow the cheap gas messes up the computer in V.. good luck
Bookmarks
