Page 2 of 12 FirstFirst 1234 ... LastLast
Results 11 to 20 of 117
    Master Mechanic Dr_Zero's Avatar
    Mar 2006
    Sunny Florida
    What years does this apply to?
    My trucks!
    1996 GMC Suburban SLT
    1997 GMC Yukon SLT
    I am new to this forum as of 7/18/09. I own a 03 Silverado Extended Cab. I signed on to find a solution to the @#%&*#$@ clunking problem in my steering collum. I found many post about this issue which surprised me as Chevy claimed I was the only one having this mystery problem. I used the post by Skinner to add a grease fitting to the steering collum. IT WORKED!! I was at the end of my rope. If this didn't work I was headed down to the local Ford dealer and trade it in. The technology available in todays trucks is amazing. Satalite Navigation, anti lock brakes, even my rear view mirror knows to automaticly dim if the guy behind me has his brights on. But they can't make a steering collum that works correctly. No wonder GM went bust.
    Captain Bones
    Chesapeake Bay Maryland
    That's the first mod I've read about for this that makes any sense. Some are taking the shaft apart, greasing and putting it back in. Seems like way more work than would be necessary. I've got a good rattle in the column when turning at speeds approaching 20 to 35 mph and it's not right. I'm still under warranty so I guess I'll try dealer first and if replacing the I shaft doesn't work I'll try the DIY method. Thanks.
    Aug 2008
    Loganville, GA
    Quote Originally Posted by magstar67 View Post
    Anxiously waiting pictures/details! I took mine to a different dealer friday for a second opinion, they put another I-shaft on it (4th one - 3 new OEM and 1 Borgeson), they also beat on the end of the column where the bearing is to make the bearing fit tighter and it still does it!!! Have had it at two large Chev. dealers and both say there is nothing else they can do to make a 27k mile truck not feel like you are driving a piece of junk! The first dealer has also replaced the steering box, lower bearing and the shaft between the I-shaft and steering box.
    You're not alone, we had the same problems with the saturn Ions and Vues. To this day I still don't think GM has figured out how to make an intermediate shaft that doesn't clunk.
    Quote Originally Posted by Captain Bones View Post
    Captain Bones
    The only modification I made to this fix was I used some expanding foam "great stuff" to plug up the end of the shaft where it connects to the steering box. I let it harden up over night and added more grease the next day.
    I have searched and wondering if I have this problem. My steering doesn't clunk per say, when I turn it almost feels like something is loose, within the system. It just doesn't feel solid. Is this the same thing you guys are talking about? If so, thanks and will try, if not sorry but can somebody maybe steer ;) me in the right direction.
    2006 Chevy Silverado Ext. Cab Short box
    Quote Originally Posted by Tight Lines View Post
    What you are explaining sounds to me to be a different issue, like the pitman arm or steering box is sloppy. This issue usually is most noticable turning on rough surface at slow speeds, but mine got tobe noticable at highway speeds in some corners where the outside tire track was rough. Felt like a bad balljoint kind of.
    If u are out of warrenty, try the grease fitting, fixes the issue instantly, read some posts, there are some good helpful ideas like the foam idea, very smart.
    skinner
    2004 Chevy Silverado Z71, 5.3L auto
    Beginning work in progress
  8. #18
    Quote Originally Posted by Dr_Zero View Post
    Someone correct me if i'm wrong but i believe 2000-2006, don't know about newer.
  9. #19
    Glad u are happy CAPITAN BONES, don't want to loose you to ford for such a simple repair lol.
  10. #20
    By the way, mine is still quiet, about 3000 miles or more now.
  1. Steering Clunk
    By alabamaxrebel in forum General Chevy & GM Tech Questions
    Last Post: 07-15-2011, 03:52 PM
  2. '99 Yukon Steering CLUNK
    By mojo1 in forum GM Powertrain
    Last Post: 02-16-2010, 04:20 AM
  3. Steering Clunk/Rattle
    By Sitkaspruce in forum General Chevy & GM Tech Questions
    Last Post: 11-19-2009, 02:49 PM
  4. Clunk in steering wheel
    By TJbear in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-13-2009, 11:29 PM
  5. clunk noise from steering
    By vegaschevy in forum Lifted & Offroad Suspension
    Last Post: 01-22-2009, 03:51 PM
