I removed my front driveshaft to replace the u-joints. only problem is they won't press out of the yoke. I even snapped an arbor press in half trying o get them out. You guys got any ideas for me to try before i bring it to a shop to have it done?
BRYAN
"IF YOU DON'T TREAT IT LIKE A TRUCK IT'S JUST A REALLY BIG CAR"
02' Avalanche 2500 Onyx Black
8.1L Vortec
43,000 miles
Have you tried putting some heat to the yoke?
2008 GMC Sierra 2500HD Ex. Cab, Fire Red, 6.6L Duramax LMM Equipped with UTG Rocker Pods
AMSOIL is the only oil company that...,"Recommends 25,000 mile oil changes","Gives up to four times better wear protection","Warranties your engine against oil related failure"
Preferred Customers Save up to 30% Click here!!!
Executive Direct Jobber ZO# 1695636
Scott Douglass 248-721-1002
Order online: www.1st-synthetics.com
It's pretty tough to do without some heat. They inject plastic in the groove at the factory to hold it in place, so the first time you replace one, you have to heat it to soften the plastic so you can push it out.
Gary
99 K 1500 Suburban
78 Silverado Big 10 w/factory 454
1977 Formula
1976 Trans Am
1980 Honda CB900 Custom
You might think about buying a cheap propane torch. The plastic will melt with just a plumbers torch
Jim
2004 SILVERADO 2500HD LS
Pro Comp Leveling Kit
Pro Comp Programmer
Bilstein Shocks
Linux Bed Liner
Tinted Windows
Other rides:
1967 Landcruiser <350 Chevy>
1970 Camaro
1990 Geo Metro Convertible
2007 FJ Cruiser
Another tip, there is ALOT of plastic in there, more then you think would come out. You need to get that plastic so hot that it is on fire so it will expand and come out. I just ran my driveshaft down to my mechanic and he did it for free for me. Good luck!
5.7 K&N & True Dual Exhaust
Hypertech III
05 17" Silverado rims
99 LS 1500 5.3 "THE MULE"
Reg Cab Long Box
285/75/16E Dunlop Rover M/T
___________________________
Jason
Got a hold of my cousin who works at an autobody shop. He said bring it by. Heated it up real good and they came out pretty easy. Then on the install a needle bearing fell behind the cross and that was that. Ran back to the parts store and bought another U-joint. So $90 and 2 days of aggrivation. I twas still better than paying someone else to do it. Thanks for the info on the plastic.
BRYAN
8.1L Vortec
43,000 miles
Bookmarks
