Results 1 to 7 of 7
    Newbie one_bad_z71 is a glorious beacon of light
    May 2009
    North Country Ny
    Default griding calipers
    hey all i switched to 15in rims and had to grid my calipers....well i have them down the point where there almost gone and my rim will move if my trucks drivin but it wont if you jack it up in the air and try to spin it..... i took it back off and didnt see a spot where its rubbin now...should i be ok to drive it or should i try to take more off ?
    Master Mechanic
    heavy chevy is a glorious beacon of light
    Feb 2009
    Texas
    for one why did you do that that is obsurde. Changing to a smaller rim messes your drive train up and everything. I know tires are not that much more expensive for 16s. It just seems to me u have messed up a perfectly good part. If the tire doesent move when it is jacked up take more off.
    08 silverado
    4.8
    K&N cai
    single in dual out cherry bomb pro
    leveling kit
    custom painted bow ties
    Bed liner
    Tinted windows
    20inch Cruser Alloy Switchblades
    Goodyear Eagle GT2 285/50/20
    1 truly heavy foot + Wait4meperformance SCT Handheld
    100 shot of Nitrous Dyno tune system
    SS front bumper
    Matching painted front grill and bow ties
    Legend tbplus10 has a reputation beyond repute
    Mar 2007
    -97.0482020 N, 32.6625890 W
    1 Post(s)
    1 Thread(s)
    Obviously the easiest answer to this is to put the 16 inch wheels back on. But it sounds like your determined to run 15's so take the wheel off spray paint the inside of the wheel with a contrasting color spray paint rebolt the wheel and spin it. Remove the wheel and look for where the paint transference is. You might be able to remove enough metal from the inside of the wheel to stop any grinding.
    Dont forget to do the rear wheels also cause the next time you need to swap wheels from front to back it'll be a cold dark night and you wont have any tools other than a jack and a lug wrench to help you.
    Tim
    2011 Silverado 1500 LT
    2008 HHR LT
    1999 Tacoma SR5 TRD 4X4
    1993 Jeep Wrangler
    1991 Toyota Rock Crawler
    2009 Harley Davidson Nightrain
    2004 Harley Davidson FLHT "Bagger"
    2003 Glastron GXL Bowrider
    Jr. Mechanic Blazerado is a glorious beacon of light
    Apr 2009
    The Dena, Maryland
    It might be hitting the control arm, that would be the first place i would check. If it only does it when the wheel is off the ground you should be fine to drive it unless it hits when you turn the wheel.
  5. #5
    May 2009
    North Country Ny
    i finally got them....only have to grind the rears...close to ten hours of grinding but it looks good with the 15'' deep dish's .... thanks guys
  6. #6
    Moderator
    dwill3015 has a reputation beyond repute
    Jan 2007
    Yacolt, Washington
    Let's see some pictures!
    Darcy
    Washington State
  7. #7
    May 2009
    North Country Ny
    if you go look at " My Z71 " in the pics section of the fourm i just put one up
Similar Threads
  1. Painted My Brake Calipers- Check 'em out!
    By adampaul1964 in forum Lifted & Offroad Suspension
    Last Post: 07-29-2011, 09:25 PM
  2. 01 1500 rear brake calipers
    By rvpc in forum Lifted & Offroad Suspension
    Last Post: 04-20-2010, 10:13 PM
  3. New calipers
    By bbwalker665 in forum Lifted & Offroad Suspension
    Last Post: 12-10-2009, 10:08 PM
  4. 2001 Tahoe Calipers Question?
    By BillH in forum Chevy Tahoe Forum (GMC Yukon, Cadillac Escalade)
    Last Post: 05-28-2006, 03:27 PM
