Results 1 to 9 of 9
    Sr. Apprentice LisaO925 is a glorious beacon of light
    May 2009
    Bay Area CA
    Default Stumped two mechanics with popping in truck
    95 GMC Sierra 2wd 2500 used to be a truck for pulling horse trailers. Then I retired it when I got out of horses, and now use it as a daily driver 180k miles on it.
    Has always been maintained perfectly. Within the last 3 months or so, I started to hear a popping while driving. I just assumed it was when I turned, so figured the ball joints needed replaced. Didnt have the money at the time, so I greased them. Still popped. Took it to a Les Schwab last weekend because of nail in tire. Mentioned the popping, they said that I needed a new Pitman Arm and Idler arm. Got it done today. When I went to pick it up, and paid the $325, I asked, "So, no more popping right??" He said that was my problem, and that everything else was tight and fine. Half way home, it started popping again. So, I called, and they said to come back down. We took it for a test drive, and really listened to when it made the popping sound...
    *Accelerating from going under 5mph, but still rolling. It does pop when turning to a slight left, but not tight left.
    *Accelerating in reverse
    *Going into my driveway, which has a low grade slope, or any low grade slope - both directions
    **Does NOT pop going over speed bumps
    **Does NOT pop turning as in a U turn or a tight turn
    The popping actually sounds like its from the back of my truck. 45 minutes later, they still could NOT figure out what was causing the sound.
    Another guy took it for a test drive, and he couldnt figgure it out. They promised me its not any bushings, no frame damage, or the bed hitting the cab or anything.
    Can anyone here tell me what it might be. Its really annoying! Its gotta mean there is a problem somewhere, and I want it fixed before something bad happens.
    Master Mechanic
    heavy chevy is a glorious beacon of light
    Feb 2009
    Texas
    Sounds like it is a wheel barring or a u joint take it to another place maby a local mom and pop place. They will get it fixed for you . I never take my stuff to a big branch. They will find the most expensive part and replace it. If it dont work they go to the next most expensive part. Mom an pops places usually will do you rite the first time. Good luck and let me know what you find out.
    08 silverado
    4.8
    K&N cai
    single in dual out cherry bomb pro
    leveling kit
    custom painted bow ties
    Bed liner
    Tinted windows
    20inch Cruser Alloy Switchblades
    Goodyear Eagle GT2 285/50/20
    1 truly heavy foot + Wait4meperformance SCT Handheld
    100 shot of Nitrous Dyno tune system
    SS front bumper
    Matching painted front grill and bow ties
    Legend Z71_guy is a splendid one to behold
    Feb 2009
    Minnesota
    sound like a u joint binding
    2003 Z71 Silverado LS
    Access roll up cover
    Bed Rails
    Billet Grill insert
    Bed Rug
    CB with PA system
    Waiting to be installed
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    Sound like u joints but do you have a locker in it? That pop could be the locker engaging or just not functioning correctly.
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
  5. #5
    Legend Jimmiee has a reputation beyond repute
    Feb 2009
    Reno, Nevada
    Sounds like a wheel bearing from the symptoms. Have you ever packed your wheel bearings?
    Jim
    2004 SILVERADO 2500HD LS
    Pro Comp Leveling Kit
    Pro Comp Programmer
    Bilstein Shocks
    Linux Bed Liner
    Tinted Windows
    Other rides:
    1967 Landcruiser <350 Chevy>
    1970 Camaro
    1990 Geo Metro Convertible
    2007 FJ Cruiser
  6. #6
    Jr. Mechanic Blazerado is a glorious beacon of light
    Apr 2009
    The Dena, Maryland
    Check the sway bar bushings by turning the wheel with it in park. If that doesnt work than try spraying the sway bar bushings down with some grease and then drive it. Hope you figure it out, we get a lot of 2500-3500 trucks and SUV's with this problem and noise. It isnt easy to pin point if you dont know. lol
  7. #7
    Apr 2009
    The Dena, Maryland
    Quote Originally Posted by LisaO925 View Post
    Hey just wondering if there is any news on a fix?
  8. #8
    May 2009
    Bay Area CA
    Funny you should ask. I finally decided last night to take it to a mechanic this AM to get looked at. I sware to you that the whole time from start up, to taking kids to school, and coming back home, I did not hear one single pop. So, I passed on the mechanic for now. Plus when I drove by they looked real busy and this is my only vehicle for right now.
    So, I am NOT sure if I should be more nervous that I dont hear the sound anymore, or feel better. Honestly, I think it freaks me out more..lol
  9. #9
    Newbie navyCM is a glorious beacon of light
    Apr 2009
    MS gulfcoast
    from what you described a "popping" and the location of sound "rear of truck" and the nature of what you used it for "towing horse trailers". thats a u-joint going out. get under your truck if you can near the rearend where the driveline goes in and twist the driveshaft and see if the u-joint moves. it should stay put and the driveshaft should twist slightly into the rear, but the u-joint should not move in the yoke.
    2006 GMC Sierra SL1 4x4, Hankook RF10 tires, suspesion maxx torsion bar kit w/ 2" blocks in the rear, more to come...
Similar Threads
  1. Need Help I Stumped........
    By Oakley10289 in forum General Chevy Tech Q&A
    Last Post: 04-03-2011, 08:00 PM
  2. Please Help, I am Stumped
    By dawolfman in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 06-06-2010, 11:01 PM
  3. Replies: 0
    Last Post: 03-30-2010, 03:10 PM
  4. Stumped on 97 GMC Jimmy problem
    By exceler8 in forum General Chevy Tech Q&A
    Last Post: 09-30-2009, 09:08 AM
  5. Stumped
    By nsanders in forum General Chevy Tech Q&A
    Last Post: 06-18-2009, 12:34 AM
