Results 1 to 7 of 7
    Newbie LT1Chevy210 is a glorious beacon of light
    Apr 2009
    Default 09 Silverado Ticking
    I have an 09 Silverado extended cab with the 5.3L that has begun to make this ticking noise. The truck currently has 1500 miles but I first noticed it at 500 miles. At first I thought it only made it when the ambient temperature was below 35 degrees. The video in the link below was taken at 65 degrees. Typically the noise occurs at initial startup and lasts anywhere from 15 seconds to 10 minutes. It sounds like a lifter issue to me. I have an appointment with a dealer on monday morning but was wondering if anyone else has experienced this problem. Thanks. Here is the video [ame="http://www.youtube.com/watch?v=5idrnVk04Aw"]YouTube - 09 Silverado Tick[/ame]
    Newbie setter g is a glorious beacon of light
    Jun 2008
    Michigan
    Nice idea capturing the clicking on video! It does not sound right to me. My 09 Silverado has about the same miles as yours and sounds smooth. I'd say this is definitely something to look into now while your truck is new. I'll be interested to know what others say might be the cause. Sadly, I am not qualified to even speculate as to the cause.
    Jeff
    2009 Silverado LT Ext Cab 5.3 L, Blue Granite Metallic
    2008 GMC Acadia , grocery getter
    Newbie kmusk64 is a glorious beacon of light
    May 2009
    Michigan
    Chevy 210, I have a 2009 5.3 Silverado. 1200 miles. I just had this happen last Thursday for the first time leaving work. Lasted about 10 seconds. Definately sounded like a lifter noise. I am curious at what they have to say. Please keep us posted. Thanks, Kevin
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    Good luck guys, I am sure they will give you some kind of "thats normal until past the break in period" line but that sounds like yuou have some oiling problems at start up
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
  5. #5
    Newbie vinceg is a glorious beacon of light
    May 2009
    Hobart Indiana
    They will say it is from carbon build up on pistons . my 02 does and always has and now it has 115,000 on it and never had a problem. did you idle it a lot in winter ? this is a common chevy problem . its caused by carbon build up and the piston rocking in the cylinder.
  6. #6
    Apr 2009
    Picked my truck up today. The problem is caused by the lifters partially draining and air becoming entrained in the oil. GM is supposed to be working on a redesigned lifter and until that process is complete, nothing will be done unless a truck is experiencing misfires or trouble codes. The tick is apparently nothing more than annoying.
  7. #7
    Jr. Mechanic bubba33 is a glorious beacon of light
    Oct 2008
    ST Louis MO area
    There have been some problems with the AFM lifters bleeding down.It is not from carbon build up on a new truck with 1500 miles on it.
Similar Threads
  1. 2007 silverado 2500HD 6.0 ticking sound
    By quakaddict09 in forum Powertrain
    Last Post: 07-28-2010, 03:55 PM
  2. 2007 silverado 2500HD 6.0 ticking sound
    By quakaddict09 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 02-05-2010, 01:38 PM
  3. 05 silverado pulsing and ticking soud
    By mickey in forum General Chevy Tech Q&A
    Last Post: 04-28-2008, 07:05 PM
  4. 05 silverado ticking and cracking under dash
    Last Post: 04-28-2008, 12:42 AM
  5. Ticking?
    By glisella in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 08-03-2006, 05:24 PM
