I just replaced both inner and outer tie-rod ends on my 2001 Suburban. I the took it to be aligned, and was told that the inner joint was too stiff to rotate for aligment. They feel that it's a defective tie-rod end. Both the left and right side are the same. I don't know what the chances of buying 2 bad parts are. Has anyone had a problem like this?
Thanks,
Steve
What brand tie rod ends were they?
Usually the joints for tie rod ends are pressed together and arent adjustable, I have had some that took a lot of effert to move but after some use they loosen up.
What was the recommendation from the shop?
Did they offer to replace them (at a cost of course).
Tim
2011 Silverado 1500 LT
2008 HHR LT
1999 Tacoma SR5 TRD 4X4
1993 Jeep Wrangler
1991 Toyota Rock Crawler
2009 Harley Davidson Nightrain
2004 Harley Davidson FLHT "Bagger"
2003 Glastron GXL Bowrider
I got the tie-rods from Autozone. Apperantly they are very stiff. I inspected them today, and was able to turn them, so I took it back to the shop and a different mechanic was able to align it. So all is well for now.
Steve
probably had the new guy working on it, we have the same problem thats why when he says something does not work a experienced tech will look at it
2003 Z71 Silverado LS
Access roll up cover
Bed Rails
Billet Grill insert
Bed Rug
CB with PA system
Waiting to be installed
Bookmarks
