Results 1 to 1 of 1
    Legend phoebeisis has a brilliant future
    Jun 2006
    River Ridge Louisiana-4 miles W of New Orleans-didn't flood-water stopped 800 yards away.
    Default Coolant leak-hose to exhaust manifold
    Help.
    I have a 209,700 mile Suburban-2wd 1998-runs great gets good hy mpg-20-21. In other words, I want to keep it until I find a better Suburban;we do long road trips and once you travel in a Suburban, nothing else will do.We sleep in it at rest stops(2 adults leggy greyhound), so huge is good.
    I have several leaks. One clear iol leak at the timing cover-no big deal.I think the oil pan gasket is also leaking-once again,so wht-I lose/use 1 quart per 2500 miles-never manages to drip to the ground-too slow.
    The main problem is a coolant leak-I lost about 2 quarts in 1000 or so miles.Once again,I don't really find significant coolant on the ground. I took a good look yesterday, and on the drivers side of the motor-kinda underneath a coolant hose that seems to go from the water pump to the drivers side exhaust manifold-I found-actually felt- a puddle of coolant in a recess flat area under/behind the valve cover.
    Of course,I can't see this hose leak, and it is covered with woven plastic "armor". Maybe it is the hose,
    BUT-will an intake manifold gasket leak pool there??
    From the PO receipts the intake manifold gasket was changed in 2005 50,000 miles ago.
    Any ideas?
    PS I took a better look/feel.It is pooling on top of the bellhousing just behind the motor.The actual coolant hose to the exhaust manifold looks ok. I wonder where an intake manifold gasket leak would pool? If the coolant was leaking to the outside-would it leak pool on top of the transmission bell housing??
    Thanks,
    Charlie
    1998 suburban-
    1/2 ton
    199500 miles
    River
    Ridge,LA
Similar Threads
  1. Broke coolant hose to manifold!!
    By philosofy1 in forum Powertrain
    Last Post: 09-15-2009, 11:34 PM
  2. coolant leak
    By ferg's04 in forum Powertrain
    Last Post: 08-17-2009, 06:48 PM
  3. Coolant line out of exhaust manifold-98 burb
    By phoebeisis in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 05-12-2009, 04:12 PM
  4. Leak in AC discharge hose
    By MrShorty in forum General Chevy Tech Q&A
    Last Post: 10-04-2008, 03:48 PM
  5. Coolant Leak
    By kjrmayfield in forum General Chevy Tech Q&A
    Last Post: 02-20-2008, 06:53 PM
