Hi all,
04 Sillverado 4x4 Z71 Crew with 92k, when I engage the 4x4 via push button there is a very loud clanking. It didn't use to be there, I am guessing I need to do some lubrication etc. but not sure where what etc. Any advice is greatly appreciated.
Happy rollin & thanks in advance.
Phil
If at first you don't succeed, skydiving isn't for you!
check your diff fluids and change that out if its not been done yet and check your linkage area's maby its out of wack wont me much cause of the pushbutton system maby something internal on the front diff if there is metal shaving in the gear oil or is silvery looking then you got problems and head straight to a gm service place or drive line shop
Is it 4 hi or low?
2005 Chevy Silverado Z71 in Black
6" BDS Suspension Lift | 3" BDS Body Lift |17" Rock Crawler Stellies | 35" Cooper STTs | 4.56 Yukon Gears | AirAid CAI and TBS | Flowmaster 40s | HyperPAC Programmer
2001 TJ Sahara in Sienna
3.5" RE Suspension Lift | 33x12.50 Baja MTZs | D30/44 | ROKMEN Merc Front Bumper | Warn Rockcrawler Rear w/ Carrier | Warn M8000 Winch
Hi,
I noticed it when I went into Low, but then it did the same thing when going into high. Though Sunday when I went into High it was quiet, "didn't try low" so it might just be Low.
Autotrac 4wd or the shifter on the floor?
Autotrac
I tested again yesterday, it is definitely when I shift into LOW. If I just go from 2 to 4 HI there isn't a noise, if I go from 2 to 4 LO there is a loud klank, if I go from 4 LO to 4 HI the same noise is there.
Thanks again
That clank is normal. I have it on mine as well. That is just the transfer case changing into low. I actually love the sound.
I also have 05 Z-71 and it klanks when shifted into low. I love the sound also!
Yeah, it lets you know that it's "in there"
Bookmarks
