Anyone know the crack for the DVD so you can watch DVD on the road
Thanks
John
i think u put a switch on the wire that runs to the e-break to the radio to fool it making it think that the e-break is on when its not. i think
hey if it is like any other aftermarket dvd player, youll need to install a switch for the ebrake.. but mae damnm sure you can hit it in a flash... dont cut the wire, just tap into it that way should you get pulled over you can still hit the brake and the caops shouldnt give you too much crud if your smart. luck!
If this is an OEM DVD player I believe it is wired into the computer as well so I dont think you can hack it. But aftermarket its linked to the ebrake
5.7 K&N & True Dual Exhaust
Hypertech III
05 17" Silverado rims
99 LS 1500 5.3 "THE MULE"
Reg Cab Long Box
285/75/16E Dunlop Rover M/T
___________________________
Jason
ya, if its afetrmarket, just do as the others have said. if its oem, they make an over-ride module...
Cody- Tulsa, OK
'04 silverado
Bookmarks
