Results 1 to 9 of 9
    Legend Springthing has a reputation beyond repute
    Aug 2008
    East of Branson, Missouri
    1 Thread(s)
    Default Have you cracked open your wiper system and played around? Got a few Qs for you..
    Ok, so I am having problems with the intermittent wipers so I've ordered a new circuit board. I found where it goes (on the firewall in the engine compartment) and opened up the box to see how it is in there. Well, when I pulled out the circuit board I found a big gob of pink, waxy lubricating stuff in there. Some of it was stuck to the board, most was in and around the gears found there.
    Does anyone know if there's supposed to be a huge gob of the stuff there?
    Secondarily, I have the wipers squeak when they are on. It's not the wipers themselves for sure. The squeak is pretty loud in the cab - loud enough for it to get on my dang nerves! Here's what I get:
    *squeak* >>>>>>>>>>>>>>>>>>>>>>>>>>>>
    <<<<<<<<<<<<<<<<<<<<<<<<<<*squeak-eak*
    Anyone played with the wiper's system enough to be able to guide me in the right direction? I've not taken off the cowl or anything so I don't know how anything looks over than what is connected and visible around the circuit board box.
    It's just strange that it's loud enough IN the cab to make it seem as though that's where the squeak is coming from... although I'm sure it's not!?
    Thanks!
    Steven
    "The Sarge"
    1999 Chevy Suburban LT- K2500
    7.4 454 Vortec, 4WD
    305/70/16 on Eagle Alloy
    Broke & Starving Student pmf608 has a reputation beyond repute
    Nov 2008
    Alberta, Canada
    12 Post(s)
    I had to replace my circuit board due to only having high speed and no return to bottom position (newer model but same idea). The grease should be there to lubricate the moving parts. Despite this grease, i think it does heat up in there because mine had a little capacitor-type-thing that had brunt off the board and actually split into 3 parts.
    As for the squeak, I'm not too sure about exactly what it could be. I know on my truck if they are not properly adjusted, my wiper arms contact my hood. I would check to make sure the squeak is not a rub between the arms and the hood. Also, because both wipers are run off a linkage to a single motor and module, I would put some lubricant or WD-40 on any moving parts between the motor and both wipers.
    best of luck, hope this helps
    2001 Silverado Reg. Cab Not-So-Base -- SOLD
    2003 Avalanche Z71. No Cladding. Time for mods...
    1974 Triumph Spitfire 1500
    1997 F-350. 7.5L. Gas-Guzzling Work Beast
    Jr. Apprentice 1995 silverado is a glorious beacon of light
    Apr 2009
    hawaii
    on mine, under the plastic guard around the wipers, there is the linkage for the wipers, maybe something is loose causing the squeek? or yah, could be the motor driving it...
    1995 silverado
    Beltech 4"drop front soon to be 6" on the back
    true dual 44 flowmasters
    Hooker comp headers
    k&n cai
    20" zenetti throwback wheels
    2 kicker 10" subs
    alpine seps
    alpine mono 500w amp
    jl 4chan 500w amp
    Jr. Mechanic Blazerado is a glorious beacon of light
    Apr 2009
    The Dena, Maryland
    More than likely the squeak is either the output shaft out of the motor which would explain the grease in the circuit board. If that is not the problem than the linkage is starting to go bad at one of the joints.
  5. #5
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    I feel your pain Springthing!! My wipers have had that horrible squeek for a couple years, it drives me banana sandwich. If you figure it our please let us know, and more importantly ME!! I havent had time to deal with mine as the nursery has drawn more attention right now. My wipers are also behaving badly, they are working when they feel like it!
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
  6. #6
    Aug 2008
    1 Thread(s)
    Thanks, all, for the information. I guess it's a matter of taking the cowling off or something to get to the linkage... I'll let you know, vnjc. I cannot STAND any type of squeak no matter where it comes from, deliberate or bump-induced!
    Steven
    "The Sarge"
    7.4 454 Vortec, 4WD
  7. #7
    Jr. Apprentice Maxx is a glorious beacon of light
    May 2009
    Michigan
    I have repaired several wiper boards that only work when they want to.
    Every time it was cracked solder joints on the PCB.
    Always at the connector to the wire harness.
    If you can solder try there first before buying a board.
    An easy way to tell is when they aren't working wiggle the plug on the motor with the wipers turned on.
    96' Silverado 4x4
    350 Vortec, 195k,
  8. #8
    Feb 2008
    1 Post(s)
    Quote Originally Posted by Springthing View Post
    Tell me about it I have owned cars for less then two weeks because of mysterious squeeks!!
    Hypertech III
    Reg Cab Long Box
    Jason
  9. #9
    Aug 2008
    1 Thread(s)
    Thanks for the tip, Maxx. I'd taken the board out and checked everything as close as possible. Thing is the boards are coated so soldering is even more of a pain in the butt! I tried that route but ended up paying the $15 or whatever it was for the new board.
    It got put in just a few hours ago. We'll see how it does in the next bit of rain.
    Steven
    "The Sarge"
    7.4 454 Vortec, 4WD
Similar Threads
  1. Cracked Navigation Screen. Help?
    By Cutter2010 in forum Audio / Video Electrical
    Last Post: 05-23-2010, 12:49 PM
  2. cracked tranny need help
    By Jplowman2005 in forum Powertrain
    Last Post: 11-21-2009, 07:43 AM
  3. Cracked leather?
    By jkk in forum Chevy Truck Accessories
    Last Post: 09-09-2008, 01:14 PM
  4. GM Recall 2008 heated windshield wiper fluid system
    By Steve in forum Automotive News
    Last Post: 08-31-2008, 11:50 PM
  5. ODB-II ..... anybody played with this? [Expired Topic]
    By MN_Burbon in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-16-2006, 06:34 PM
