Results 1 to 9 of 9
    Jr. Mechanic willbradfan is a glorious beacon of light
    Jan 2009
    Colorado
    Default Rough idling in Park or Neutral
    I only get a rough idle when the gears are in Park or Neutral, any other gear the idle is smooth when I just have my foot on the brake. When in park my battery charge is right at the 14v charge rate, i started messing around and I pressed all of my window buttons down at the same and realized that my volt charge drops under 14 and my idle smooths out. Any ideas what could be causing this??
    K1500 5.7L Chevy Suburban
    290000+ miles
    K&N CAI
    Black Bear Performance Tune
    TCI Servo and Shift Kit
    Long Tube Ceramic Pacesetter Headers
    Custom Side Swept Dual Exhaust
    Dual 2.5in electric DMH Performance Exhaust Cutouts
    BFG A/T 285s
    Master Mechanic
    heavy chevy is a glorious beacon of light
    Feb 2009
    Texas
    could be that you need to change your plugs and wires. Just a suggestion on that.
    08 silverado
    4.8
    K&N cai
    single in dual out cherry bomb pro
    leveling kit
    custom painted bow ties
    Bed liner
    Tinted windows
    20inch Cruser Alloy Switchblades
    Goodyear Eagle GT2 285/50/20
    1 truly heavy foot + Wait4meperformance SCT Handheld
    100 shot of Nitrous Dyno tune system
    SS front bumper
    Matching painted front grill and bow ties
    Jan 2009
    Colorado
    Quote Originally Posted by heavy chevy View Post
    The plugs were replaced around last december, but I don't think i have replaced the wires in 1.5-2yrs maybe? They are the platinum napa wires that have a lifetime warranty, some shop put them in when I was out of town and the driver of my suburban needed to get it fixed to drive.
    290000+ miles
    K&N CAI
    BFG A/T 285s
    Master Mechanic
    Feb 2009
    Texas
    check fuel filter and make sure your air filter is clean
    08 silverado
    4.8
    K&N cai
    leveling kit
    Bed liner
    Tinted windows
    SS front bumper
  5. #5
    Jan 2009
    Colorado
    Just replaced fuel filter not to long ago and just cleaned the K&N filter as well. This has been bothering for me awhile and ive just been living with the rough idle for the past 6months and nothing has popped up that could direct me to the problem, tempted to just leave it alone again but if anyone has any other ideas im glad to hear them, would be nice to have a smooth idle in P or N again.
    290000+ miles
    K&N CAI
    BFG A/T 285s
  6. #6
    Legend MrShorty has much to be proud of
    Jan 2006
    Utah
    What year?
    Any vacuum leaks?
    '98 K1500 Suburban LS 5.7 L 4L60E NV246 ARB
    '92 Ford Explorer XLT 4x4 4.0 L A4LD BW13-54 Trac-loc rear
    "My toys were the greasy cogs and springs and pistons that lay around all over the place, and these, I can promise you, were far more fun to play with than most of the plastic rubbish children are given nowadays." Danny in Roald Dahl's Danny The Champion of the World
  7. #7
    Jan 2009
    Colorado
    Quote Originally Posted by MrShorty View Post
    What year?
    Any vacuum leaks?
    It is a 1996, didn't realize my year of the suburban was the only thing missing in my sig..
    I have never checked for vacuum leaks as I am not very familiar with anything related to the vacuum system on vehicles.
    290000+ miles
    K&N CAI
    BFG A/T 285s
  8. #8
    Jan 2006
    Utah
    Locate vacuum hoses (like the one going to the brake booster) and make sure they are all connected and there are no signs of leaks/hissing.
    I might put a fuel pressure gauge on it and make sure fuel delivery is up to snuff.
    Any codes/pending codes in the computer? If you have a scanner, it might also be useful to look at some of the PID's while the engine's idling to see if there is anything obviously out of range.
  9. #9
    Jan 2009
    Colorado
    I noticed that the vacuum line that connects to the brake booster was sort of damp where it is hose clamped onto the booster, it shouldn't be wet in any way right? The only scanner I have is a cheap $80 scanner from walmart that allows me to pull the service codes, ive been meaning to invest in an actual scanner that i can get real time data from the engine, any recommendations on the scanner. I will have to go check some other vacuum lines. any other major vacuum lines that you could easily point out? Thanks!
    290000+ miles
    K&N CAI
    BFG A/T 285s
Similar Threads
  1. Egine runs rough while idling
    By Bear945 in forum General Chevy Tech Q&A
    Last Post: 09-12-2009, 04:21 PM
  2. Idling rough....
    By hairysox33 in forum Powertrain
    Last Post: 02-02-2009, 04:26 PM
  3. URGENT: 2002 Suburban Z71 Idling Rough and Surging
    By perfect777 in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-14-2009, 10:33 PM
  4. 2005 tahoe idling rough
    By zach91 in forum Powertrain
    Last Post: 01-25-2008, 04:39 PM
  5. 92 Burban w/350 idling alittle rough
    By jbird in forum Chevy Suburban Forum (GMC Yukon XL)
    Last Post: 01-23-2008, 09:39 AM
