I have a 1982, 2500 G.M.C. suburban, 2wd. I want a 4wd. Is it possible to do a 4wd conversion, or is the design of the frame going to interfere? If the frame will not work, what about a 4wd drive frame, lift the body, pull engine, trans, everything else, and throw a different frame under. The body is in great shape, as is the interior. And this it the suburban from my childhood. That’s why I don’t want to buy a different truck. Any thoughts?
Thanks, Aaron.
It's possible to do a solid axle conversion on your truck but if you dont have a lot of fabrication skills and experience setting up suspensions you'd be better off dropping your body on a 4x4 frame.
I think either conversion would cost about the same $$.
Tim
2011 Silverado 1500 LT
2008 HHR LT
1999 Tacoma SR5 TRD 4X4
1993 Jeep Wrangler
1991 Toyota Rock Crawler
2009 Harley Davidson Nightrain
2004 Harley Davidson FLHT "Bagger"
2003 Glastron GXL Bowrider
Bookmarks
