Thread: Body Work
    Jr. Mechanic MXZ1983's Avatar
    Apr 2008
    Platteville, WI
    Default Body Work
    Ok, so here goes... I have the 93 silverado and im starting to get a hint of surface rust just bubbling through the paint on my cab corners. I'm thinking about doing the whole bottom (the tan part) in the black spray on rubberized undercoating stuff. I will take off my running boards, sand the tan where it isnt rusty to get it a little rough to get it to stick, and sand the "rust" spots down to bare metal and prime it there.
    I have a couple of questions for this
    1) If i sand all of the tan, after priming the "rust" spots that were down to bare metal, do i need to prime the rest of the bottom of the truck?
    2) Do i need to sand the primer or will the rubberized undercoating stick to the primer
    3) What grain sandpaper do i use for sanding the tan where it isnt rusty to get the undercoating to stick to it better.
    Any in put with these would be great.....thanks guys, i know you will all help where you can...
    2002 Chevy Avalanche 1500 Z71, Black with heated leather, moonroof, roof rack, everything :)
    Sold :( '93 Silverado K1500, extended cab, 3" body lift, true duals, 3"X14" Polished Stainless tips, no cats, Pacesetter Headers, dynomax muffler, diamond plate toolbox with 3' CB whips on both sides, Clear headlights and directionals- sold with 140k
    Aug 2008
    East of Branson, Missouri
    Quote Originally Posted by MXZ1983
    No, not necessarily. Before you put primer, though, let me suggest a little bit of rust treatment if there is any pitting. For the rest of the paint.. scuff (sand) it and blend the primer to the rest, making sure everything is well feathered. While you have the primer in the gun, though, I'd go ahead and spray everything.
    Sand the primer. It never hurts to sand any surface prior to any sort of paint.
    Go for a 600. This will be a rough sanding - don't do too much or you'll go right through the paint.
    Keep in mind that prior to painting any coats, primer or otherwise, clean the surface well with a light swipe of acetone or rubbing alcohol after washing with soap.
    Good luck.
    Steven
    "The Sarge"
    1999 Chevy Suburban LT- K2500
    7.4 454 Vortec, 4WD
    305/70/16 on Eagle Alloy
    Jr. Apprentice AUSTING64's Avatar
    May 2009
    DES MOINES, IA
    I work in a body shop and i would have to agree with springthing was and grease remover works good to clean the surface to
    2008 1500 LTZ 5.3L V8
    *LIFTED
    *EDGE EVOLUTIOIN
    *KMC WHEELS
    *ALPINE SYSTEM
    Apr 2008
    Platteville, WI
    ok, i cant really get ahold of a primer gun, im gonna have to use primer spraypaint, so im gonna get like rust oleum or something, a good brand not cheap, do i still paint all of the tan or just the bare metal areas? thanks for the help guys. And just lightly go over all the tan with 600 and the undercoating will stick to that ok?
    appreciate the help... just want to do it right so it looks good.
    Legend bry2500's Avatar
    Oct 2008
    Gloucester, MA
    One thing about rust repair is trying to stop it completely. If you have a concern about it returning in the same area this maybe something to consider. It is a little on the expensive side, but a well respected custom car mechanic in my town recommends this stuff.
    http://www.por15.com/POR-15-Rust-Pre...nt/products/1/
    BRYAN
    "IF YOU DON'T TREAT IT LIKE A TRUCK IT'S JUST A REALLY BIG CAR"
    02' Avalanche 2500 Onyx Black
    8.1L Vortec
    43,000 miles
  1. Chevrolet : Silverado 3500 Work Truck duramax work truck special use body
    Last: 07-14-2010, 07:40 PM
  2. New Lights & Body Work
    By ZSI52 in forum Chevy Truck Accessories
    Last: 04-27-2010, 01:47 AM
  3. AnyBody around St.Louis That can do body work?
    By dans02silverado in forum MO - Missouri Chevy Truck Club
    Last: 02-13-2010, 01:04 PM
  4. Fresh Body Work, Tell Me What You Think
    By 1_low_rider in forum Chevy Truck Accessories
    Last: 06-07-2009, 01:02 AM
  5. Paint Job and Body Work...
    By Crawdaddy in forum Chevy Suburban Forum (GMC Yukon XL)
    Last: 05-07-2007, 11:01 AM
