Results 1 to 4 of 4
Thread: Extra Wires
    Broke & Starving Student pmf608 has a reputation beyond repute
    Nov 2008
    Alberta, Canada
    12 Post(s)
    Default Extra Wires
    When I was working on my truck today, I found some extra wires that aren't being used. I had taken the underhood fuse block shroud off to make room to drill a hole in my firewall for my amp power wire. Under this cover, I found two wires and a three-wire plug that were not being used. I was wondering if anyone knows if they have these wires, or if anyone knows what they would be for.
    I thought the red wire might be for some sort of accessory like the light in my canopy, but it is too well integrated into the factory harness all the way through inside the truck even for a professional installer to have done it.
    The blue wire with the plug I have no idea about - it has the same connecter as my HID headlight ballasts
    The three-wire plug also baffles me - I have no idea what would plug into that. I know the picture is not very clear for this one. The wire colors are brown-black stripe (left), black (center), and brown (right)
    Thanks in advance for any help.
    Attached Thumbnails Attached Thumbnails Click image for larger version
ID:	2760   Click image for larger version
ID:	2761   Click image for larger version
    2001 Silverado Reg. Cab Not-So-Base -- SOLD
    2003 Avalanche Z71. No Cladding. Time for mods...
    1974 Triumph Spitfire 1500
    1997 F-350. 7.5L. Gas-Guzzling Work Beast
    Legend Springthing has a reputation beyond repute
    Aug 2008
    East of Branson, Missouri
    1 Thread(s)
    Just took an initial look on my '99 and I couldn't find anything that looked like those. It's dark, though, and I was working with a flashlight. Hopefully someone will be able to give you a hand!
    Steven
    "The Sarge"
    1999 Chevy Suburban LT- K2500
    7.4 454 Vortec, 4WD
    305/70/16 on Eagle Alloy
    Former Member TRPLXL2 has much to be proud of
    Jan 2009
    Norwalk, Ohio
    2 Post(s)
    1 Thread(s)
    Well I know this isn't going to help but I'l post it any ways, that plug connected to the blue wire is a Delphi Packard connector A.K.A. Gm uses them on everything, hell I even bought some to use for my headlight halo connections! The one wire plug (orange) almost looks like a knock sensor plug, and as far as that 3 wire plug I have no idea. Well if anything this post will bring you back to the top!
    Nov 2008
    Alberta, Canada
    12 Post(s)
    I just thought I would bring this thread back in case anyone else found these wires on their truck and was wondering. I found out while doing some research in preparation to install trailer wiring for all possible functions that the red wire is a power wire for a trailer brake controller and connects to stud 2 in the fuse box. It is on all trucks, and should not be connected unless a trailer brake controller has been installed at some point. The blue wire is the trailer brake output from the controller. It will only be found with an open connector on trucks without the towing package (aka HD trailer wiring), since the LD trailer wiring includes lights and ground only run to the back of the truck, with the brake output left under the fusebox.
Similar Threads
  1. extra outside lights
    By Jimbo3 in forum Chevy Truck Accessories
    Last Post: 09-14-2009, 01:34 AM
  2. TBSS gets a few extra ponies
    By JennaBear in forum Chevy Trailblazer Forum (GMC Envoy)
    Last Post: 09-06-2009, 11:56 PM
  3. extra lights
    By coombia21 in forum General Chevy Tech Q&A
    Last Post: 07-24-2009, 06:48 PM
  4. Extra power out of a 5.3?
    By 5point3 in forum Powertrain
    Last Post: 06-03-2009, 03:39 AM
  5. Aftermarket Sparkplugs wires vs Chevy Sparkplug wires
    By chevy00 in forum Chevy Silverado Forum (GMC Sierra)
    Last Post: 10-19-2005, 11:17 PM
