Hey all.
Any (more) suggestions for lifting my 1999 2WD Suburban LS body? I just want enough lift to give the C1500 the look and body height of a C2500. I like the slight rake to the front the vehicle has now. I am guessing that a 3" lift all around would just about right. Any ideas, comments, or criticisms?
All ideas are welcome!![]()
I posted on your suburban section post, but if you want it level either lift the front only or you will need to lift the front higher then the rear. Depending on the rake of your suburban it may be a 3-1, 3-2, 4-1, 4-2 or just put in 2" spacer up front but you should be able to get spring spacers for a 2WD and then a block for the rear
5.7 K&N & True Dual Exhaust
Hypertech III
05 17" Silverado rims
99 LS 1500 5.3 "THE MULE"
Reg Cab Long Box
285/75/16E Dunlop Rover M/T
___________________________
Jason
Bookmarks
