Results 1 to 9 of 9
    Newbie pittbull is a glorious beacon of light
    Apr 2009
    Unhappy loud ticking
    my 1997 4x4 chevy suburban is making a ticking noise when i step on the gas pedal to pass a car or to pickup fast speed.
    Jr. Engineer thrasher is a glorious beacon of light
    Dec 2008
    Norwalk, CT
    Sounds like it could be a leaking exhaust manifold gasket.
    You're driving is WAY more offensive than my swearing, mothrafocker!
    Sr. Mechanic RATRODKING is a glorious beacon of light
    Dec 2008
    south florida
    maybe a lifter tapping ?
    check the oil level.
    leonard
    Jr. Engineer
    97chevz71 is a glorious beacon of light
    May 2009
    Perry County, Pennsylavania
    Quote Originally Posted by pittbull View Post
    Normal valve tap my friend never hurt anything. I have the same thing in a truck does the same exact thing.
  5. #5
    Apr 2009
    Quote Originally Posted by 97chevz71 View Post
    I was told that it was a piston. oil level is good
  6. #6
    Jr. Apprentice jester is a glorious beacon of light
    May 2009
    Utah
    I doubt it is a piston. That would be more of a knock than a tap. I agree it is probably a vlave tap or maybe exhaust manifold gaskets
  7. #7
    Legend unplugged has a reputation beyond repute
    Sep 2006
    High Deserts of SoCal
    Does the noise go away after warm up? Piston "slap" usually goes away once the engine has warmed up. Piston slap is caused by a scuffing of the piston skirt. Not normally something to be concerned about.
    Underhood ticking noises typically come from four sources: Tappet noise, piston slap, spark plug wire arcing, and exhaust manifold leaks.
    Plug wire arcing and exhaust manifold leaks are easy to identify with a visual inspection.
    Tappet noises that aren't cured by proper oil level can either be ignored or replaced. Replacement doesn't always guaranty the noise will go away.
    Piston slap while annoying isn't bad for the engine. GM has introduced a polymer coated piston as a fix.
    This piston knock anomaly that has been occurring in some ’97-’01 engines after start-ups in cold weather is not a durability concern. It’s a pleasability issue on which there was enough input from customers that GM made a production change. Like the revised rings, there’s no performance advantage in switching to the tighter clearance and the polymer-coated piston. Those hearing a cold piston knock are better off ignoring it until the engine warms a little, rather than subjecting themselves to the stress of a dialog with a GM dealer intended to force repair or replacement of the engine.
    There is no way to happiness....happiness is the way.
    http://kx6ijq.blu.livefilestore.com/y1pcOFVNH4ix1hjyGUVyXK5LRfef7qSeWzlZDorpQhIEfkZ2ZA  _vXMYypuKMJFw671uF2ZPhjez_j-atRmcjM2zQKpQi1JSsB75/burb1.JPG
    High Desert SoCal
    93 K1500 burb (personal) 350 AT 3" Lift 250K+
    02 Honda Civic LX
    Looking for a 1990's Miata for an engine swap
  8. #8
    Apr 2009
    The ticking turned to a loud nocking sound. if I take the oil pan or the valve covers will i see if the problem.
  9. #9
    Apr 2009
    O and no the noise doesn't go away when is warm
Similar Threads
  1. Loud A/C compressor
    By TJbear in forum General Chevy Tech Q&A
    Last Post: 06-22-2010, 11:15 PM
  2. Subs too loud
    By 02 Heavy Chevy in forum Audio / Video Electrical
    Last Post: 04-02-2010, 01:06 AM
  3. Loud Cat Back exhuast
    By firecatf7333 in forum Performance & Fuel
    Last Post: 12-07-2009, 10:12 AM
  4. Loud fuel pump on 02 Sub.
    By lgp927 in forum General Chevy Tech Q&A
    Last Post: 07-31-2008, 10:01 PM
