Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Jr. Apprentice jicurtis is a glorious beacon of light
    Aug 2008
    Broomfield, Colorado
    Default Towing in the mountains vs flat land
    I have a 2008 Suburban 1500 4x4. To the best of my knowledge I can tow a max of 7000 lbs according to the literature. My question is how much can I tow in the mountains of Colorado, like on I70 going west it will be over 10,000 feet going thru Eisenhower Tunnel. I dont want to hurt my transmission or engine from over heating. I am trying to decide how heavy of a Camping trailer to buy....
    Sr. Apprentice TexasT is a glorious beacon of light
    Nov 2007
    Texas
    Quote Originally Posted by jicurtis View Post
    Remember the 7K# includes all the gear, water, and anything else you plan to put in the trailer. Also you need to look at the GCWR. This is the total weight of the truck, trailer, people and gear. 7K# seems like a lot but water and gear is heavy and it fills up fast.
    The lightest would give you the ability to carry more "stuff", but might not get you the amenities that you want.
    Rich
    If I didn't have a Suburban I couldn't pull the toy box and haul my family to use the toys.
    Jr. Engineer L0sts0ul is a name known to all
    Feb 2007
    Edmonton, Alberta, Canada
    2008 Chevrolet/GMC Suburban/Yukon XL 1500 4WD 5.3L V8 7000lbs
    Requires 3.73 axle ratio
    2008 Chevrolet/GMC Suburban/Yukon XL 1500 4WD 5.3L V8 8000lbs
    Requires 4.10 axle ratio
    Your total hauling ability for your truck is 7000lbs if I understand your setup correctly.
    Now, I agree completely with texasT in that you have to account for the whole shooting match. When you look at a trailer it will say on the production sticker inside a cupboard or something inside the trailer what the GCVW is. That is the MAX capacity that the trailer will haul (called Wet Weight). your DRY weight is the GVW ( i believe). You need to keep the TOTAL WET WEIGHT BELOW 7000lbs. I would leave at least 1000lbs for a variable problem that you may not know about. say you forget to empty your wastewater tanks before you leave (easily 1000lbs).
    Now, onto something else. Your truck is cooled more effeciently than mine is. BUT, these are the 3 things I would consider.
    1.) A transmission cooler, they are relatively cheap ( about 150 bucks or less + install ) This will keep your transmission fluid cooler, and last longer on the long hauls (only problem I had was that my fan wasn't cooling it well enough, so I have to keep moving to keep the cooling up).
    2.) you NEED a tranny temp guage. Keep an eye on the thing to know where you are at, so you know when you HAVE to stop vs when you THINK you have to stop... trust me ive hauled through the mountains, and you need to know when you have to slow, and gear down.
    3.) look into a Oil cooler for your motor. I am getting one in a couple of weeks, and from what ive seen, using an oil cooler extends the life of your motor 10 fold, and reduces a lot of problems when towing.
    one more thing... if you get the chance, and have the funds, always use the thickest oil the journals on your motor will support. ( newer motors, and more finicky even 10w30 can screw with it sometimes) .
    I run 10w30 year round in my truck, but I use Quakerstate 4x4 and it seems to keep oil pressure up better than anything else Ive tried. but an oil cooler would help that even more.
    1993 K1500 Suburban 350TBI, 378,486KMS on frame, 49,000KMS on Drivetrain. Lots of mods, built for haulin trailers and haulin @$$
    2000 K2500 Yukon XL 6.0L Vortec 252000KMS custom CAI, and exhaust...but not done yet.
    "If you are dumb enough to do something you don't know how to do, and can't do it safely then WHEN you get hurt its your own fault...BONEHEAD"
    Aug 2008
    The trailer I am looking to buy is 5200# UVW, I have estimated adding about 500# to the trailer and an additional 500# to the back of the Suburban. That would be bring me to about 6200#. I have also taken out 130# of weight(3rd row seating), so I would have about 930# less than the 7000# max. Do you think I should be ok in the mountains? Do any of you have experience pulling a trailer thru the mountains?
  5. #5
    Feb 2007
    as a personal choice I try to stay 500 to 1000# below GVCW.
    yes I have towed in the mountains, and you NEED a tranny cooler at least, and always tow in the lowest possible gear when climbing and use the trailer brake as much as you can when you are going down hill.
  6. #6
    Newbie kmcelyea is a glorious beacon of light
    Apr 2010
    Longmont, CO
    jcurtis - I am curious. What kind of trailer did you decide on? And did you you come to the Colorado Mountains? I live in Colorado and I have a 21ft Trail Cruiser travel trailer. It weighs 3000lb (dry). I have towed it for several years with my Jeep Grand Cherokee (4.7L HO V8 and 3.73) and I really do not have that much trouble in the mountains. The high compression really helps control the downhill speed. I now have a new Suburban 2008 1500 4x4 because we really are quite crowded in the Jeep. The Jeep's tow rating is 6500lbs so I am hoping the Suburban will do as well or better than the Jeep and give my family and 3 large dogs a more comfortable trip. The weight really does add up. I figure with full tanks, a portable generator, 3 kayaks, 300 pounds of dogs and 400 pounds of people and all their stuff (inclucing bikes) I gotta be pushing 5000 lbs. I have towed for thousands of miles with the Grand Cherokee and I know most people will say that it isn't the best tow vehicle. The only issue I have had is that my Jeep is a full time 4WD and it seems that the axles need servicing about every 20000 miles.
    I am looking forward to towing with the Sub. How did yours do?
  7. #7
    Jr. Mechanic Sandhopper is a glorious beacon of light
    Feb 2010
    Amarillo, Texas, United States
    I pulled a 25' travel trailer all over the east coast with our 02 Yukon XL 3.73 rear 1500. The Total weight of the trailer was about 6K loaded. No problems with the mountains of PA or NY. It did have the trans cooler though which was included with the HD trailering package. We have not towed with the new burban yet.
    2010 Suburban Z71 5.3 A6, Sheer Silver, Ebony Interior
    2004 Lexus RX330 AWD - Netune Blue Metalic
  8. #8
    Master Mechanic bigdaddy77084 is a glorious beacon of light
    Jan 2010
    Houston, Texas, United States
    Ya cant get any aftermarket helper springs for the back?? My grampa had an old 1/2 ton with a 3/4 ton rear end and springs . He pulled his boat and hauled firewood with it forever..
    95 tahoe 2dr 4x4 200,000+ miles
  9. #9
    Legend vncj96 is a name known to all
    Feb 2008
    Red Wing, Minnesota, United States
    1 Post(s)
    Dont let the computer do all the work either, get the truck prepared before you head up or down the mountains. Overdrive should only be used when on flat while towing, manually drop it down to 3rd. the computer will only downshift when it has too and to make up for the lose of power it will drop to second which isnt always needed. This will help greatly
    5.7 K&N & True Dual Exhaust
    Hypertech III
    05 17" Silverado rims
    99 LS 1500 5.3 "THE MULE"
    Reg Cab Long Box
    285/75/16E Dunlop Rover M/T
    ___________________________
    Jason
  10. #10
    Aug 2008
    The trailer I purchased was 5,120 lbs dry, guessing it is about 6,000 wet with all of our stuff in it. So I am about 1,000 lbs under the max. Our 08 Suburban 1500, 3.73 rearend pulls it great on flat land or in the mountains. my first test was going to Brainard Lake in Colorado, the campground is over 10,000 feet. No problems at all pulling the trailer up there, no over heat, and the transmission stayed under 230 degrees. I am very satisified with the performance. I hope this helps everyone!!
    Jim
Similar Threads
  1. howdy from the mountains
    By Loggerhead Mike in forum Member Introductions
    Last Post: 08-26-2009, 03:45 PM
  2. 1500 HD heating up towing up mountains
    By henrys021500hd in forum General Chevy Tech Q&A
    Last Post: 03-09-2009, 01:03 AM
  3. Greetings From the Rocky Mountains
    By Montana in forum Member Introductions
    Last Post: 03-03-2009, 03:43 PM
  4. 08 z71 4x4 flat towing
    By jaccirose in forum General Chevy Tech Q&A
    Last Post: 11-13-2008, 01:04 PM
  5. Hummer land
    By Steve in forum Hummer Forum
    Last Post: 06-01-2007, 09:58 AM
